10-05-2016, 02:57 PM | #1 |
Jeep spring swap question
1961 put jeep tj springs anybody chime in that's done this swap. What shocks and do they need relocation? What about pan hard bar do I need an adjustable? Thanks for any help
10-05-2016, 04:01 PM | #2 |
Re: Jeep spring swap question
I have TJ spring on a '66. I used the shock studs from the front mounted on the outside of the frame, and stock front shocks on the rear. The lower shock mounts were flipped (had to drill a new hole in each). Not sure if this would work on a '61 but it's much better than the stock location.
Frizzle Fry posted a how-to here: http://67-72chevytrucks.com/vboard/s...postid=4730005
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
10-05-2016, 09:41 PM | #3 |
Thanks for the tips and info
10-05-2016, 09:55 PM | #4 |
I had stock jeep tj springs and shocks left over from when i lifted my jeep. I ended up putting both the springs and factory jeep shocks on my 65'. Shocks bolted right up to the factory position on my truck, and ride better than the old worn out truck shocks did. Everything was a direct swap.
10-06-2016, 12:06 AM | #5 |
60-66 Nut
The '60-'62's had rear mounted shocks from the factory, but at more of an angle to the rear. The dampening effects of the shock would improve with the shocks mounted more vertical as shown in the pic above.
10-06-2016, 09:38 AM | #6 |
Not stock trailingarms but my shocks on the '62
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
10-06-2016, 08:41 PM | #7 |
Anyone ever done air shocks to help with load capacity when needed? The tj springs seem pretty weak but since they were 20 dollars thought I would give them a try.
