Old 10-05-2016, 04:06 PM   #1
71chevc10
strange wiring problem need help
Hey all
I have a 1971 c10 lwb.
The problem is when i push down on the brake pedal the right turn signal lights up for as long as i hold the pedal down the trun signal still works and flashes when operated
any suggestions would be appreciated
thanks
71chevc10 is offline   Reply With Quote
Old 10-05-2016, 04:19 PM   #2
kwmech
Re: strange wiring problem need help
Turn signal switch
Old 10-05-2016, 04:42 PM   #3
71chevc10
Thanks KWMECH
Much appreciated!
Old 10-05-2016, 05:03 PM   #4
Mike harris
sounds like a bad earth problem, i used to have the same problem but it was when i put full beam on, cleaned up connections on dash and switches, hasn't done it since
Mike harris is offline   Reply With Quote
Old 10-05-2016, 05:07 PM   #5
71chevc10
thanks Mike
