Old 10-08-2003, 06:07 PM   #1
restart42
Junior Member
restart42's Avatar
Weatherstrip removal
Hey guys and dolls, Can anyone tell me how to remove the old stuck on adhesive used to glue on the weather stripping to the panel/barn doors of a 71-72,Suburban. Is there a special solvent I can use or do I have to grind the suff off ???? Sure would appreciate the help,,,, Pat
Pat
72 GMC Suburban,4X4,402BB
restart42 is offline   Reply With Quote
Old 10-08-2003, 06:31 PM   #2
truckster
truckster's Avatar
3M makes a weatherstrip adhesive remover.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-13-2003, 02:28 PM   #3
restart42
Junior Member
restart42's Avatar
Adhesive remover
Truckster,, Tried the 3M Adhesive remover, didn't work to well
as it's made for lite stikky stuff like bumper stickers, decals and rubber glue.
Any body out there know of any heavey duty stuff, before I get the ole grinding wheel out???????
Pat
Old 10-13-2003, 03:03 PM   #4
Woody
Just a guess but, using a heat gun might work.
Woody is offline   Reply With Quote
Old 10-13-2003, 03:54 PM   #5
greasemonkey
greasemonkey's Avatar
Try the weatherstripping adhesive remover like truckster said, not regular adhesive remover. It works.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 10-13-2003, 04:20 PM   #6
tom hand
CCRider
tom hand's Avatar
A wire wheel on a die grinder or drill works well
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 10-14-2003, 03:50 PM   #7
restart42
Junior Member
restart42's Avatar
thank's guys,, will go to Home DEpot istead of auto storefor "weatherstripping" adhesive remover
Pat
Old 10-14-2003, 05:16 PM   #8
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Why take it off? If you can't get it off just glue the new stuff over the top of the old glue. You're gonna cover it up anyway...
Yeah, I know, Lazy - that's me!
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 10-14-2003, 05:50 PM   #9
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Did you use the 3M Adhesive Remover (SMART)? Side Moulding And emblem Removal Tool lubricant? That should remove the weatherstrip adhesive.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-16-2003, 03:28 PM   #10
restart42
Junior Member
restart42's Avatar
Tom, the wire wheel got off the remnants of the old rubber ,but the glue still hard to remove
71GMC3/4T-Need to remove glue to treat rust underneath,
Black&Blue - went to 3 auto stores,they don't have "side moulding & elblum removal tool lube"
I'll just keep at it with the wire wheel,heat gun and the 3M stuff,,
Thanks guys for the helpful hints,,,,
Pat
