Brand new steering shaft, still lots of play
Hi all,
Working on my 67 k10 with power steering, I recently installed LMC's "tilt column install kit" which includes a rag joint, intermediate shaft, and a U-joint for the end of the column. The DD intermediate shaft slips in to the rag joint just fine and everything looks nice. However, the slip joint has a severe amount of play (severe for a brand new part anyway) that will translate into a few degrees of slop at the steering wheel. I don't see how I could have installed it wrong, is there something I'm missing? Does the sleeve need to be crushed a bit or maybe filled with silicone?
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
Re: Brand new steering shaft, still lots of play
My guess is simply poor manufacturing tolerances on that part. The repro stuff out there - particularly from LMC, in my experience - isn't that great.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
I feel the same about LMC, some stuff is great, some stuff is not...I should be able to put that sleeve in a press and crush it a little bit, right?
![]() Join Date: Nov 2004
? Are you sure that's where your play is coming from? That *looks* like a snug fit to me, are you sure the play isn't in your steering box?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Good point... also double-check the intermediate shaft slip joint, as they can easily have some play.
That's definitely where all the play is coming from, everything else is rock solid. Maybe I can find some metal shims to jam in there? What's the purpose of that slip joint anyway?
The purpose of that slip joint is in case of a front end crash that needs to be able to compress to stop you from eating the steering wheel.
You could probably pinch it lightly in a vice to smash it a bit tighter... not sure that I would do that vs. just sending it back and getting a better one though. |
Moderator
![]() Join Date: May 2007
This.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
the boat guy
Heat it red hot, then quickly cool. Should snug it up a bit. Or crush/bend slightly. Or put a small tack weld on it.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
I promise you guys it's not the gear box or anything in the column, it's this slip joint
![]() I guess tomorrow I'll put some heat on it and see if I can close that tolerance up. Seems ridiculous that I'm having to do this to new parts. I'd return it but I already cut the shaft down to size so I doubt they'd accept it.
Just an update, some heat and a vice did the trick!
