Old 10-06-2016, 03:54 PM   #1
crakarjax
crakarjax's Avatar
Custom Panhard to Frame Mount (with heim)?
Has anyone fabbed or purchased a panhard to frame mount that allows a dropped or adjustable end link height wrt the frame? I have a CPP deluxe bar and I'm thinking of swapping the adjustable end link out with a heim and installing a custom bracket to get the bar more level at ride height.
I've currently got some 2" square tube that I'd planned to use to fab a mount but now I'm thinking there might be something more elegant/strong available on the aftermarket.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 10-06-2016, 03:57 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Custom Panhard to Frame Mount (with heim)?
Check with Porterbuilt www.pbfab.com or No Limit engineering www.nolimitengineering.com
Keith
Convert to disc brakes.
Old 10-06-2016, 05:52 PM   #3
tinydb84
tinydb84's Avatar
These are for my watt's link but you get the idea.
David
Instagram: myfabguy
Old 10-06-2016, 06:15 PM   #4
crakarjax
crakarjax's Avatar
That looks pretty cool, how thick is the steel you used there?
pbfab and nolimit don't have just the brackets listed, and pbfab doesn't even have pics of most of their products so it's impossible to tell what I'd be getting anyway.
Old 10-06-2016, 06:17 PM   #5
tinydb84
tinydb84's Avatar
Originally Posted by crakarjax View Post
that looks pretty cool, how thick is the steel you used there?
Pbfab and nolimit don't have just the brackets listed, and pbfab doesn't even have pics of most of their products so it's impossible to tell what i'd be getting anyway.
3/16''
David
Instagram: myfabguy
Old 10-06-2016, 06:52 PM   #6
SCOTI
SCOTI's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=368476
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-06-2016, 08:49 PM   #7
crakarjax
crakarjax's Avatar
Originally Posted by SCOTI View Post
That looks perfect, I like the channel vs a series of holes for adjustment but I think I might just weld to the frame to save some time/metal. Where did you find those high misalignment spacers?
I was initially thinking that I could mount some tube where the original mounts and then weld to that a section that drops down, kind of like an upside-down "L". If I do that then I could use the provided poly bushing because the tube would be at the right angle. The tube I got is 1/8" wall so now I'm worried that it wouldn't be beefy enough... and I have no idea how to calculate the required bracket strength
