10-06-2016, 06:31 PM | #1 |
20' Daredevil (Ret)
Drip Rail Reseal
My old stuff was breaking up and I was pulling chunks out of the drip rail so it's time to fix it. Never done this before so I read through some old threads. Good news is there's only light surface rust underneath and it's nearly all wire-brushed out now.
I'll spray with NAPA Permatex rust treatment #765-1671 first, but I'm not sure what to do next. I had figured on painting, then applying seam sealer, then painting over that. Or should I skip the first coat of paint and apply seam sealer directly over the rust treatment, and then paint? Thanks, guys. Old man here but a rookie when it comes to stuff like this.
10-06-2016, 06:54 PM | #2 |
Re: Drip Rail Reseal
I'm wanting to know this as well.
10-06-2016, 07:44 PM | #3 |
Im in too...
10-06-2016, 07:53 PM | #4 |
I did the same. I sealed over the rust reformer then I painted. did this about two months ago no problem so far. just smooth out the sealer best as you can. I used my finger.
10-06-2016, 10:40 PM | #5 |
Post Whore
Had the same issue on my Suburban except it was like 30 more feet. I removed as much of the old sealant and rust as possible, treated with Por 15, scuff sanded and the used Ospho on the spots that I sanded through. Then shot a coat of epoxy sealer over everything, taped off, and then resealed with a two part seam sealant. There was one spot I had to put some punch and hammer action on to close up the gap. It looks as if my burban was a Monday or a Friday truck as the roof just doesn't fit the cab very well, but was good enough for them, on that day. There is some more info in the Working Man's Burban thread in the 67-72 Suburban section.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-07-2016, 09:58 AM | #6 |
Good info
1972 C/10 Cheyenne, Daily Driver. SOLD 1978 GMC K15 High Sierra. |
10-07-2016, 01:58 PM | #7 |
How did you fix that part that you had to cut out? What do you do if you have spots that have rusted through with little pin hole spots?
10-07-2016, 02:47 PM | #8 |
I'm interested in this thread also. I'm also interested if anyone has a good fix for the inside of the cab on the metal below the drip rail. I can get a patch panel for the front from sun visor to sun visor but I haven't found any for the area above the doors.
10-07-2016, 09:43 PM | #9 |
I wouldn't trust a rust treatment. Try applying it to something rusty, and then sand it. I'll bet you'll find the rust is still there.
10-07-2016, 11:36 PM | #10 |
20' Daredevil (Ret)
Well, I treated the area this afternoon. In the 45 years since my truck was built, there was only very light surface rust anyway. I removed nearly all of it (always gonna be a small amount you can't reach). If the Permatex stuff does even a fraction of what it claims, it oughtta be good to go. Plus it's gonna get a fresh coat of paint and then seam sealer.
10-08-2016, 02:03 PM | #11 | |
Post Whore
10-08-2016, 10:16 PM | #12 |
I don't understand putting POR15 on then ospho. Wouldn't you want the ospho directly n the rusted bare metal you want to treat?
I also don't understand the not trusting rust treatment. Why not? That stuff works. It is proven science. And if that's not good enough, I say it works from experience. When I did mine I used a rust convertor after wire wheeling, primed, painted, seam sealed, primed, painted. I want primer under all my paint
10-09-2016, 02:11 AM | #13 |
Post Whore
In my opinion nothing sticks to clean, dustless rust and seals it better than Por15. The problem I have found is that not everything sticks to Por15. So if you are putting short strand or putty on over your Por 15 it most likely will peal off, unless you scuff it up. Scuffing it can cause small spots of rust to show through if your not careful. So to be sure that I don't have untreated rust I apply a light coat of Ospho and let it dry 24 hours before covering. The putty's and primers seem to have no problem sticking to the Ospho. This is just how I do it and I have evolved to this system as I have found it to work for me. I agree with you. Rust converter's work and work well. Most of the problems I have encountered over the years were self inflicted. In all honesty I will point out that have never built a show car/truck and all my cars live in the world outside. And in that context the new formula paints will fail long before the repair does. For my next project I am half temped to drive to Mexico and bring back some old school acrylic enamel paint, that will last more than 6 or 7 years.
10-09-2016, 08:01 AM | #14 |
Ok, thanks for explaining. I know that POR stands for Paint Over Rust. That is the whole idea behind the product and others like it. It would be nice if they came out with a POPOR-15 product... Prime Over POR-15.
I have done my '72 twice. First I used 3M's seam sealer. It was nice to work with, came out looking great. The truck also sits out. About a year later, after all my very thorough effort, I looked up there and could see the sealer had let go of the front edge ever so lightly. Don't use this stuff on external areas! It remained pliable and when I rolled it back at that separation I found I could pull it all loose. Next thing I knew I was pulling it all out in one long stretchy piece. Water had been getting down under it. It was wet when I removed that stuff. It didn't do any damage, yet, but rust started to develop. The paint had crackled up due to the pliant nature of the product. I did the whole process all over again using a product my paint supplier recommended. I'd have to look into what it was called, can't recall. I know there have been threads on best products, but it would help to know that to make this process a true success. Can people who respond also list what product they used? My '67 project cab is all clean metal with all sealer removed and epoxy primed at the moment and I want to get it right.
10-09-2016, 06:23 PM | #15 |
20' Daredevil (Ret)
For better or worse, the seam sealer got laid down a few minutes ago. My local NAPA had nothing in stock so they ordered a tube. I didn't know what they got in until this afternoon. Turns out to be 3M #08367 which is a black tar-like substance and is not self-leveling. That's OK as long as it stays in place and keeps the tinworm at bay. It's definitely an old work truck and not a show piece (can't bring myself to call it a beater), so results trump beauty. Smoothed it out with my finger as I laid it down. Pretty sure I have had nastier stuff on my finger at some point, and it came off with Fast Orange. Next is primer & paint within a day or two and I can put another little project to bed.
10-09-2016, 07:27 PM | #16 |
Proprietor of Dale's Corner
Subbed to see your results...
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
10-09-2016, 10:19 PM | #17 | |
Post Whore
10-10-2016, 08:33 AM | #18 |
Stocker, the 3M product I got at NAPA off the shelf wasn't the same. I'm sure it wasn't black. Whatever I used acted just like silicone, but paintable. Might be good for hidden areas but sucks for exterior.
And HO455, thanks for that info. I knew from other threads the opinion was the best product was a 2-part but I didn't know who it came from. Shoulda figured SEM. It seems (keep wanting to type seams) everything they make is top shelf
10-10-2016, 01:24 PM | #19 |
I can't remember who said from this thread that 3M's seam sealer wasn't for exterior must have gotten the wrong 3M product #'s. This is what the Auto Collision Shop I worked for used and it was 3M's Brand # 08531 called Heavy Drip-Chek Sealer. Google the name 3M and search #08531 Heavy Drip-Chek Sealer and this is what comes up for the product; **Designed for filling "exterior" automotive "visual definition seams". Seam Sealers are used for sealing the lap points of two metals over lapping each other and then are painted over.
If you don't want to use any kind of seam sealers then sand Blast the areas as good as you can then Epoxy Primer Seal and use Body Filler (Bondo) over it and again use the Epoxy Primer if you want to but can also finish up with just Primer Sealer or a Sandable Primer then Color paint the areas. |
10-10-2016, 09:42 PM | #20 |
20' Daredevil (Ret)
Well, that was a bust! I blame myself, not the product. Told you guys I was new to this sort of project. Anyway, the 3M sealer laid down okay for a work truck. Unfortunately I got some over the masking tape, and after primer & paint, I tried to remove the tape. Lifted the edge of the sealer and it went downhill from there, tried to remove it and the mess kept getting worse. Oh well, nothing ventured, nothing gained. I'll sleep on it, but right now I'm tempted to take it to the shop. Need to find a good shop, sadly there's none near here.
10-10-2016, 10:26 PM | #21 | |
PS you don't need a Shop to do what you can do for yourself. But hay its your money. |
10-11-2016, 12:24 AM | #22 | |
20' Daredevil (Ret)
10-11-2016, 01:35 AM | #23 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
This is for the drip rail, http://3mcollision.com/products/seal...ler-08307.html Great stuff. I wire wheeled the channel clean, wire brush the channel splices, power wash and rinse, and blow dry with a blower or compressed air. I spray Rustoleum Rust Reformer in the rusty cracks and crevasses and then shoot the whole rail with zinc primer. Then apply the sealer from center of cab out and down each side. Have your small brush and butter knife handy because as you apply a thin coat down the radius, you'll help level and feather the bead at the end of the channel. Might as well spring for the applicator and some extra nozzles. I can do one drip rail with one 200ml package. You can use the 8329 controlled flow formula on the radius area if your not comfortable with the self leveling. Wax paper and masking tape help at the gaps in the splices.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
10-11-2016, 02:45 PM | #24 |
I need to have mine done, hope it's not too bad.
10-11-2016, 03:28 PM | #25 | |
Go Pack Go!
