no horn
can anyone help me with wiring up my horn I just purchased a 1969 c10 step side SWB and I am removing and older Grant steering wheel and adding a new one. the old wheel had no working horn and pieces missing like the cancel cam for instance. I am trying to get the new wheel horn to work properly. I am wiring the horn from the battery to the horn out of the horn to wiring harness using the black wire going to the signal switch because there are no wire someone cut them out my problem is no matter how I try and wire up the horn when I attempt to connect the harness the horn blows something appears to be wrong in the way it is wired what is the correct way to wire up the horn running all new wires need help this is driving me crazy
#2 | |
The Older Generation
Re: no horn
Read through this thread and see if it helps.... http://67-72chevytrucks.com/vboard/s...d.php?t=707526 LockDoc
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: no horn
Inside your harness from the battery, you have a battery feed, alternator, feed,and regulator feed junction. with a large red wire included that runs to the firewall junction block below the master cylinder.
This wire goes into the cab and makes a junction with three other red wires. One goes to the ignition switch, and one to the headlight switch, another goes to the fuse panel, and lastly is a red wire to the horn relay. The relay is located just below the steering column and to the left of it. The horn relay wiring and plug is a red green and black wire. The red wire is the full time power wire for the relay, and the green wire is the connecting wire that delivers power back out in the engine compartment to the horn. Inside the relay is an electromagnetic coil which is connected to the red wire on one side, and to the black wire for the ground side. The black wire runs from the horn relay up to the steering column connector, and up into the column to the horn button. When the horn button is pressed it grounds the black wire and completes the circuit to the electromagnetic coil which closes, and connects the red and green wires and sends power to the horns.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
