10-07-2016, 01:16 AM | #1 |
Help with Dana 44 front axle
Which direction does the chamfer face on the thrust washer that is on the stub shaft? I can't get the small snap ring on when I put my locking hub in. Wondering if the thrust washer may be my problem. Driver side went together with no problem.
10-07-2016, 01:49 PM | #2 |
Re: Help with Dana 44 front axle
It should face towards the u-joint
10-11-2016, 09:29 AM | #3 |
You can reach in behind, and push out out the stub, while trying to put the snap ring on.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
10-12-2016, 09:09 AM | #4 |
I've had the problem a few times and it was the bronze wheel bearing spacer placed in the wrong place. IIRC it was outside the outer bearing instead of inside the inner. #52
http://77cj.littlekeylime.com/Spicer...re_Dana44_.gif Been a while, but I think I remembered it right.
10-12-2016, 09:19 AM | #5 | |
51 is the thrust washer.
10-16-2016, 07:59 AM | #6 |
You're right. Typo. Te seal would go directly onto bearing and in the picture you can see 52 is same dia. as the spindle bearing
