![]() Join Date: Feb 2003
Headlights on 83 1 ton not working
All of the lights on my 83 are working except the headlights. If there is a thread on the board, I can't seem to find it. Could someone help me out or possibly tell me where to start to find the problem? Not much of an electrician and not a lot of patience.
Thanks. |
Re: Headlights on 83 1 ton not working
I had something like that happen on my 87, just one light wouldn't work. Ensure that it isn't a bad bulb or fuse first. Un-crimp the bayonet plug that attaches to the headlight, then touch the wire to a test light. (The kind that lights up when you have a complete circuit). If you get a light, then just clean up the bayonet plug, and crimp or solder the wire back on. If you still have no lights, check your ground. Hope this helps.
Thanks.
Post Whore
![]() ![]() Join Date: May 2015
Could possibly be the switch is bad..I had one on my 86 go bad years ago..do the park lights work ?
Yes, park lights work. Just seems to be the headlights that aren't working.
Had similar thing on my 83, turned out it was dimmer switch.
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" ![]() |
Gentleman Jim Driver
x2
Check the floor mounted dimmer switch. Stomp it a couple times and it might clean the contacts and work again. Even if that does work, I'd replace it before it does it again...
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
