Old 10-08-2016, 12:21 PM   #1
D13
D13's Avatar
Can a burnt frame be reused?
I tried search but really didn't find what I was looking for.
I have decided to build a truck 'my way'. One of the components of this is 4wd. I have or can easily get access to everything I need except a frame, cross members, and front suspension hangers. All of my 2wd frames are 1/2 ton and as I researched the bending moments indicate that the 4wd frames are stiffer and seem to be the same 1/2 to 3/4. Which leads me to my question.
Very local there is a 1/2 ton 4wd that went through a fire, bad enough that there is no paint on the cab or bed sides, no interior, etc. However it is complete, and since I would be totally redoing the frame on whatever I bought, removing the toasty body is not an issue.
Can I use this frame for my build?
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 10-08-2016, 01:05 PM   #2
bbbc10
Diggin The SquareLife
Re: Can a burnt frame be reused?
I wouldnt
bbbc10 is offline   Reply With Quote
Old 10-08-2016, 03:49 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
If it was from a total burn, it is warped. Even just an engine bay fire will usually result in enough fatigue in the frame it gets some sort of damage/warping.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 10-09-2016, 12:06 AM   #4
Gmc.guy
Gmc.guy's Avatar
I think it might be ok. But the bad end of might wouldn't show up unless it failed, I likely wouldn't use it, I don't think you could really test it. A from scratch build would be worth waiting for a nice frame
-Cody
Gmc.guy is offline   Reply With Quote
Old 10-09-2016, 12:13 AM   #5
67swb72klb
67swb72klb's Avatar
Pics would help depends on how hot it got
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 10-09-2016, 10:20 AM   #6
Dead Parrot
The question you need answered is did the frame get hot enough that when it cooled, the metal's properties were changed. Frames need to flex many times without cracking. Heat and cool metal wrong and it becomes hard and brittle. Not what you want for a frame.
Was the fire in the cab or was the whole truck in a structure that burned? A simple cab fire could well have left the frame undamaged since the cab floor would shield the frame from the worst of the heat. If the whole truck baked in a garage fire, the frame is likely toast. An engine fire that spread probably cooked the front of the frame to the don't trust point.
Dead Parrot is offline   Reply With Quote
Old 10-10-2016, 02:19 AM   #7
andrewmp6
Just depends how hot the fire got,But its kinda a gamble and not one i would make myself.
andrewmp6 is offline   Reply With Quote
Old 10-10-2016, 12:22 PM   #8
daddyjeep
daddyjeep's Avatar
I would think Dead Parrot would get the prize for the best answer. My concern is the same, did the frame get hot enough to become brittle. That question itself would lead me to find another frame, regardless of the answer.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
