Power steering diagnosis help
So, stopped off at the parts store for a new headlight. Got back in the truck to leave and steering was really stiff. Drove the truck home. Fluid was low but still showing on the dipstick. No whining or growling from the PS pump. Just really odd. Other relevant facts...1972 GMC 1/2 ton 2wd LB, steering gearbox replaced a year ago, lowered 5" in the front with most suspension parts replaced. Have been driving it for a year with the current setup. Any advice on where to start diagnosing this?
Re: Power steering diagnosis help
I've been driving my 4x4 almost 20 years and same thing happened to me this weekend. Sprung a leak on top of the gearbox too. Anyone?
'72 K5, known as 'the Fox.' |
![]() Join Date: Oct 2014
I'm dealing with same problem. When I start driving the steering is fine but after it is warmed up the steering is real tight when I try to park. As long as I'm rolling it is fine. Fluid's full and it has a rebuilt Cardone pump from Rock Auto. 4500 miles on the pump. Mine is a 68 2WD
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
I've got a gearbox ordered under my lifetime warranty. My hydraboost works just fine, so I don't think it's the pump.
Now the gearbix is 'backordered' and O'reilly doesn't know how to hnor the warranty. Gonna try a box off a newer truck to see if it fits... how long did GM use the 72 stock box?
I am a Referee of life.
The later gearboxes are 3 1/2 turns "lock to Lock". The originals are 4 1/2 turns LTL. Later box is a variable not that it makes any difference t the discussion. I find the original gearbox to be too soft "Squishy" if you will, for my taste. The later box has more feedback feel to it in my opinion and I used one in my 68. I think 73 was the first year for the newer box.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Deland I find the last quote on page offensive !
Gearbox in and hydraboost replaced. Stiffness is gone, but not as loose as I'm used to. The pump whines like it's low on fluid some now. I'm guessing air that has yet to work it's way out. Maybe back off the top bolt a quarter turn or so? Also, best method to clock the steering wheel?
Note: my 18-year-old receipt with part number translated to a gearbox off an '86 Silverado. Smaller input shaft required a $60 coupler (rag joint). The return fluid fitting had to be changed too. Otherwise, bolted up as it should.
'72 K5, known as 'the Fox.' Last edited by mister.freeze; 06-17-2017 at 11:32 PM. |
