Old 10-08-2016, 05:38 PM   #1
Darelray
7 Pin Trailer Connector / Trailer Brakes
As I started to unwrap the rear harness to uncover the unterminated Red and Blue wires needed to install a brake controller I also found an unterminated white wire. Before I start tracing this wire I thought I would ask if anyone knows what this wire is for?
Thank you in advance
Darelray
Darelray is offline   Reply With Quote
Old 10-08-2016, 07:30 PM   #2
oilmanpat
Re: 7 Pin Trailer Connector / Trailer Brakes
Possibly a third brake light wire or a ground.????
oilmanpat is offline   Reply With Quote
Old 10-08-2016, 09:16 PM   #3
ChevyTech
White is used for ground on many trailer harnesses.
Old 10-08-2016, 09:57 PM   #4
sntrym95
sntrym95's Avatar
^^ Yes it's a ground.
Mike
sntrym95 is offline   Reply With Quote
Old 10-09-2016, 08:56 AM   #5
95 S_Trucker
95 S_Trucker's Avatar
The small gauge white wire is for a third brake lamp on a cap. The ground for the 7 pin harness would be a large gauge wire. It may not be present, but you can use the ground at the left frame rail.
95 S_Trucker is offline   Reply With Quote
