Old 10-09-2016, 12:14 AM   #1
Mrturner1
Show me your lowering kits and ride heights
Well I'm starting my suspension once again and I'm ready to but lowering springs, but I can't base my spring purchase off of the truck as it sits because the current springs are so old they are sagging, and I'm sure it's already a couple inches lower than stock hieght. My truck is a 1970 LWB, and it's going to have 17" or 18" inch rims when it's done. It also has 3" exhaust but no tailpipes yet because I need to lower it first. I don't want to C notch anything, but I do want it pretty low. I've come to terms with the probability of doing spindles too which I had wanted to avoid. I think 3 inches in the front is as far as you can go without spindles correct? If so, a few pics of a 3/5 drop would be great, and also a 4/6 just in case I decide that I have to go spindles. Also did you guys with 3" exhaust have to cut holes in your crossmember? Thanks you guys
Matt
Mrturner1 is offline   Reply With Quote
Old 10-09-2016, 04:20 AM   #2
GR8-68
GR8-68's Avatar
Re: Show me your lowering kits and ride heights
I wouldn't think your suspension is sagging nearly two inches, that is a lot. But if you are not wanting to do a c notch then you don't want to go 3/5 or 4/6 they recommend a c notch for anything below a four inch drop.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 10-09-2016, 04:36 AM   #3
66clow
66clow's Avatar
3 5 is fine without a c-notch. 6 is doable as well in the rear but really cutting it close. 6 you will likely hit on bumps or hauling stuff. Would c-notch at 6. I have turndowns but not 3 in.
66clow is offline   Reply With Quote
