Old 10-09-2016, 02:07 PM   #1
of13swc
Air bags
Can yawl help me out. Looking for a air ride set up that is easy on the wallet. Any suggestions where to find a nice kit?
of13swc is offline   Reply With Quote
Old 10-09-2016, 04:43 PM   #2
Hansome
Re: Air bags
www.airbagit.com or www.airbagparts.com seem to be your best bet,
G'luck
Hansome is offline   Reply With Quote
Old 10-10-2016, 09:38 AM   #3
LVPhotos
LVPhotos's Avatar
Re: Air bags
RideTech for rear cups and amazon. Firestone 2600 front and 2500 rear for me. But 2600 can be used rear as well.
https://www.amazon.com/gp/aw/d/B00AP...Q-L&ref=plSrch
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-10-2016, 01:21 PM   #4
tinydb84
tinydb84's Avatar
Re: Air bags
Don't go with airbaggit.
http://www.azproperformance.com/Budg...63-72-C10.html one of out venders here. Great place to buy from and super helpful.
David
Instagram: myfabguy
Old 10-10-2016, 08:11 PM   #5
64shortbox
64shortbox's Avatar
Re: Air bags
of13swc, when you say easy on the wallet I'm not exactly sure what you mean. Let me introduce myself - I'm the CHEAPEST SOB you will ever meet in your life. I bagged just the rear of my 64 C-10. I bought a used air bag set up that originally came off a S-10. I got a Viair 380C compressor, steel braided hose with check valve, an air tank, air pressure gauge, a pair of ContiTech air bags and cups for the air bags for $100.00 off craigslist. I would have preferred Firestone bags but there's nothing wrong with the ConiTechs - as a matter of fact I again bought air springs for my 06 F-250 USED off craigslist so I could level it when towing my 8,700 LB travel trailer and they were also ContiTech bags. The S-10 cups for the air bags naturally didn't fit my 64 so I made my own from some scrap 4" pipe and 1/4" plate we had at work - over kill but it is what we had laying around in the scrap pile. The air tank was too big for my use and I just ran schrader valves to my bumper brackets but in hind site I would have mounted them to the unused holes in my license plate frame like I did my F 250. I leave my 64 bags at 45 PSI and the truck sits where I like it and rides great. I'm adding the compressor & tank to my F 250 so I can adjust it when towing my Travel trailer. 20 PSI when towing & 5 PSI empty. My 64 sits & rides perfect at 45 PSI & for my application there is no need to keep adjusting the air pressure for my C 10.
64shortbox is offline   Reply With Quote
Old 10-10-2016, 10:13 PM   #6
mehoff400
Re: Air bags
damn you!... for that kit how could i not air bagged my truck
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 10-11-2016, 02:23 PM   #7
Pro Performance
Pro Performance's Avatar
Re: Air bags
http://www.azproperformance.com/Air-Ride-Parts/
http://www.azproperformance.com/Pro-...its-67-72-C10/
Just let us know if we can help, and can put together something for you.
We have a lot of different options for bagging these trucks, using quality components. Just send us a PM, email or call us, and be glad to help. Answer any questions you have and find or put together a kit that works best for you.
Travis
travis@azproperformance.com
480-420-8175
Pro Performance is offline   Reply With Quote
Old 10-12-2016, 11:26 PM   #8
scum1
scum1's Avatar
Re: Air bags
the "budget" kit from the az pro guys is definitely your best bet as far as cheap and reliable. its a great start. I went almost the identical package, pieced together myself. from there i put in a c notch, then cupped lower control arms, then took the c notch out and put a small step notch in..it kind of gets addicting the lower you go haha..but again. you can't get a more inexpensive kit that includes everything you need to get going. I also have that c notch and a pair of cupped lower control arms i would like to get rid of if your interested. good luck!
scum1 is offline   Reply With Quote
Old 10-15-2016, 01:33 PM   #9
of13swc
Re: Air bags
Thank you guys for all the responses.
