Old 10-08-2003, 09:30 PM   #1
Adam12
I hate trannys
Adam12's Avatar
motor getting to hot then not starting
Today I was with a friend picking up his dads dry cleaning, and when we were waiting in the drive through my temp went from 190 to about 215 in about 2 mins. I knew it was getting to hot so I shut it off. When I went to start it again it wouldnt turn over it barley started to, sounded like my battery was dead. I have heard of starters getting to hot then not working could this be the cause? or would it be because I have an electric f uel pump and 2 electric fans that are not on switches? or a combonation? Also while im on the topic how hot is too hot for a motor to run?
70 SWB 481 ci, TH-400, Edlebrok Victor Jr. intake, Holley street avenger 770, Dynomax ceramic coated headers. Dual flowmasters. and only 3516134 more little things to do.
Adam12 is offline   Reply With Quote
Old 10-08-2003, 09:33 PM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
How's the coolant level? Is it full or really low?
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-08-2003, 09:37 PM   #3
Adam12
I hate trannys
Adam12's Avatar
It was too hot for me to check...I will try to go start it again in a few mins, good thing it was only a few blocks away.
Old 10-08-2003, 10:04 PM   #4
Adam12
I hate trannys
Adam12's Avatar
Just tried again, wouldnt start. Looks like im gonna have to try and jump it.
Old 10-08-2003, 10:40 PM   #5
Glen
there are several things to check first being the condition of the battery.
second heat can cause more strain on the starter but usually that is a condition where the solenoid wont kick in at all, just a single click sound.
Third....that symptom is usually found to be too much initial advance, with the heat factor thrown I would check timing first.
Glen is offline   Reply With Quote
