![]() Join Date: Feb 2009
Instrument cluster questions
Just pulled this cluster. Anyone happen to know what this hole marked with a "?" in the cluster is for? It had nothing going to it, and I believe the same applies to my other truck. Perhaps it just takes a bulb and socket like most of the others? The manual says it's an Instrument Cluster Light.
The manual also says the hole (marked "OK") is an Instrument Cluster Light. But this takes a socket fed by a black wire, which appears to come from the turn switch. Thank you ![]() ![]() ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-09-2016 at 08:45 PM. |
Re: Instrument cluster questions
theyre both just lights need those black holders the others have
I didn't see that one marked to cluster that's the one for the prndl light should go in one of the missing bulb sockets there probably near the spedo
The Older Generation
firedemon is correct.... The one marked "Cluster" is the fiber optic for the gear indicator on the column. It goes in the hole by the speedo marked "OK" The other one just takes a regular bulb & black socket. LockDoc
Ah ha!!!!!...........Thank you. I lost track of the end of the connector (to gear indicator) when I pulled the cluster. Fiber optic huh? Now where getting serious........Thank you for the help.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
By the way, sure A LOT of details and parts on the LH cab. Holy smokes.
