Old 10-09-2016, 11:48 PM   #1
minitruckr28
help please no power to the fuse box
Hi I have a 86 chevy k10 with the 305 and 4 speed. I am not getting power to the fuse box ? The previous owner swapped the battery cables around and it hasn't turned over since. It has been covered to a carb. Has hei distributor and a brand new starter. Thanks for the help
minitruckr28 is offline   Reply With Quote
Old 10-10-2016, 10:24 PM   #2
HAULIN' IT
Re: help please no power to the fuse box
You need to be looking at the fusible links at the starter...either left off when the new starter was installed or burnt when this "swapped battery cables around" stuff was going on. The wire should go from the starter to the junction block above the brake booster & then a wire over to the fusebox. Hope this helps, Lorne
HAULIN' IT is offline   Reply With Quote
Old 10-11-2016, 01:19 AM   #3
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
x2
Also check to see the ground cable is properly attached.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
