Old 10-10-2016, 11:15 AM   #1
dme922
dme922's Avatar
Np 205??
Im having trouble getting my NP 205 to shift from neutral to 2 hi. It will shift to 4 lo but its like its still not in 4 wheel drive. Does anyone know what position the two shafts going into the transfer case should be in while its in the different selections? Thanks for any help
dme922 is offline   Reply With Quote
Old 10-10-2016, 02:12 PM   #2
obijuan
Re: Np 205??
All the way out is 4high. All the way in is 4 low. One click forward from high is neutral.
you sure your floorboard isn't hitting the shifter?
obijuan is offline   Reply With Quote
Old 10-10-2016, 02:33 PM   #3
dme922
dme922's Avatar
Re: Np 205??
Yes its not hitting. I have been building this truck for five years so i didnt know if it just needs some moving of the gears.
Old 10-10-2016, 02:37 PM   #4
dme922
dme922's Avatar
Re: Np 205??
Do i need the trans in neutral while shifting the transfer case?
Old 10-10-2016, 02:42 PM   #5
obijuan
Re: Np 205??
No but it helps to rotate the shafts to line up the teeth for engagement
