10-08-2003, 09:56 PM | #1 |
Firefighter
Power Brake Boosters Question
Why do some of the '67-'72 power brake master cylinders tilt up and some tilt down? mine on my '72 angles down and I have seen others that angle down, but I have seen several that angle up also. Another question what kind of master cylinder should be on a '72 with power brakes? Should it be the double bail oval looking one, or the single bail rectangle one? Everytime I have gotten one they give me the rectangle looking one.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
10-08-2003, 10:34 PM | #2 |
20' Daredevil (Ret)
Good question...
Pretty sure mine's all OEM (well, I did replace the master cylinder, but with the same type). It angles down because that's the way the firewall-to-vacuum booster bracket is made. And the MC is the double-bail oval type.
10-08-2003, 10:36 PM | #3 |
Watch out for your cornhole !
72 used two different types. 1 bail and 2 bail
1) Delco Moraine 2) Bendix If the parts guy doesn't ask which one you have when buying a master cylinder, you've got a 50/50 chance.
10-08-2003, 10:46 PM | #4 |
I installed a factory setup on mine and it points down and has 1 bail. I thought mine was wrong, until I saw some others with the same setup.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
