10-10-2016, 05:24 PM | #1 |
Leaking temp switch
Hi all,
I have my temp switch for my electric fans installed in my passenger side head. I did not use pipe tape or dope as I was told it could result in a Bad connection therefore not being able to produce the necessary ground. Therefore, the issue now is that that I have a coolant leak here and I am scared to tighten the temp switch anymore. Any suggestions ? Thank you in advance |
10-11-2016, 06:23 AM | #2 |
Re: Leaking temp switch
Pipe.dope works.well without a big risk of eliminating the.ground
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
10-11-2016, 10:04 AM | #3 |
Yea you need some sort of Teflon or dope, two wraps of Teflon tape has never caused me any issues.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
10-11-2016, 01:45 PM | #4 |
20' Daredevil (Ret)
Try a thin coat of teflon-based pipe dope with a couple wraps of teflon tape over it. This was recommended years ago by a plumber and it's worked for me every time. When you tighten your switch or sensor, there'll be plenty of metal-to-metal contact for a good connection, and the tape & compound will fill & seal the gaps between threads to prevent leaks.
