Old 10-10-2016, 11:48 PM   #1
zicc1835
zicc1835's Avatar
placement of overflow tank
looking to see how anyone has this tank installed pics would help going in a 72 with BB
zicc1835 is offline   Reply With Quote
Old 10-11-2016, 10:22 AM   #2
In The Ten Ring
Re: placement of overflow tank
I wish I had pics but I've put some thought into this future challenge. A member put his (made from plastic pipe) on the passenger side, between grill and radiator core support.
Depending on the diameter of this thing you have, it could go on either side of the radiator, on the engine side of the radiator core support.
In The Ten Ring is offline   Reply With Quote
Old 10-11-2016, 11:41 AM   #3
LongBox
The PO of my truck put the overflow on the driver's side, radiator support, right next to the rad. It looks like a plastic windshield washer bottle, but it has two rubber hoses going into the cap: one for coolant in from the rad, the other for any possible overflow.
Looks factory. I will try to get a picture later today, and post it up.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 10-11-2016, 01:54 PM   #4
zicc1835
zicc1835's Avatar
It's about 2.5 or less than 3 if it was round Thanks I'll give that a look and see where there is room and post up results thanks again
Old 10-11-2016, 01:57 PM   #5
zicc1835
zicc1835's Avatar
Thanks at the least I can see where it's mounted and see how I can make mine fit
Old 10-11-2016, 07:55 PM   #6
LongBox
Here's two shots (I hope)
Rick
Old 10-11-2016, 09:30 PM   #7
hardwaycooke
hardwaycooke's Avatar
I recognize that...here's where it was on mine..
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
hardwaycooke is offline   Reply With Quote
Old 10-11-2016, 10:13 PM   #8
zicc1835
zicc1835's Avatar
Just a little familiar 😎
Thanks very much I am assuming the overflow hose was running down under the rad and back u to the overflow tank
