Old 10-11-2016, 08:13 AM   #1
jbgroby
jbgroby's Avatar
New Aftermarket Horns
I picked up a new Aftermarket replacement horn from Checy Duty and noticed it has two spades for connection, the old one only had one. I'm still working our the column wiring issues, so I cant test just yet, any thoughts?
jbgroby is offline   Reply With Quote
Old 10-11-2016, 09:26 AM   #2
65sub
65sub's Avatar
Re: New Aftermarket Horns
Either two different tones or one spade is for a ground.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 10-11-2016, 10:03 AM   #3
jbgroby
jbgroby's Avatar
I assumed that the body would ground to the rad support.....
Old 10-13-2016, 05:18 PM   #4
AcampoDave
AcampoDave's Avatar
It could be that the second spade allows you to connect an auxiliary lead to another horn for two tone applications.
AcampoDave is offline   Reply With Quote
Old 10-14-2016, 08:06 AM   #5
ratskin
If you look closely, you'll see they're the same terminal. For dual horns.
ratskin is offline   Reply With Quote
Old 10-14-2016, 08:38 AM   #6
jbgroby
jbgroby's Avatar
cool, thanks
