10-11-2016, 11:21 AM | #1 |
Painting Stock Exhaust Manifolds
What is every body using to seal your Ram Horns (for people that use them) after they have been sand/media blasted? thanks
10-11-2016, 11:45 AM | #2 |
Re: Painting Stock Exhaust Manifolds
I have used the high temp coating from por15. Seems to hold up well
10-11-2016, 11:47 AM | #3 |
I've used this in the brush on style with great success.
http://www.eastwood.com/factory-gray...p-coating.html |
10-11-2016, 01:49 PM | #4 |
Por has worked well for me also.
1972 Chevy C10 Custom Deluxe Highlander 1972 Chevy C10 Custom Deluxe Medium Green |
10-11-2016, 01:52 PM | #5 |
10-11-2016, 01:59 PM | #6 |
Yeah' well sometimes nothin' can be a real cool hand Lucas Jackson |
10-11-2016, 07:13 PM | #7 |
I have had very goof luck with blasting amd vht flame proof paint
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
10-11-2016, 07:23 PM | #8 |
Moderator
POR 20 hi temp coating. Done.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
10-11-2016, 08:00 PM | #9 |
I had a buddy who worked at an airport hangar, and he managed to get my exhaust manifold, for another car, aluminized. A really durable and good looking coating, made the engine compartment look very "detailed", and never needed any work for over 20 years.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
10-11-2016, 09:48 PM | #10 |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
My dad used to work at Appalachian stove and would get me some spray paint called stove bright that they painted the wood stoves with. I would wire brush the manifolds, wipe them down with lacquer thinner, let it dry for a couple hours, spray 2 or 3 light coats....not too heavy, just full coverage. Stuff lasted for years with daily driving, only minimal touch up from time to time. Use a curing process to finish it off by firing the engine up and bring the manifold up to about 250-300 degrees, let cool and repeat a couple times for best longevity. You can still buy it off the web for about 10 bucks a can last time I bought it. Stuff smells wicked so I don't think it's simply common paint. Beautiful metallic cast iron finish too!
10-12-2016, 07:17 AM | #11 |
Cast grey color is what you want if wanting the correct "new" look. The POR and Eastwood products give you that. Eastwood offers quality stuff that is more expensive than their equivalent, if you know where to find it. In other words, the company that makes the paint. I find it at major swap meets. I never used the POR product but the Eastwood stuff works great. Sandblasting is the key to success for whatever way you go. There is ceramic coating but that's a silver, stainless looking color. VHT is actually good stuff, again, over sandblasted surface.
10-12-2016, 09:10 AM | #12 |
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
10-12-2016, 04:58 PM | #13 |
I painted the stock manifolds on my 69 more than 20 years ago with the stuff that Eastwood sells. They still look good.
"Negative people always seem to have a problem for every solution" |
10-12-2016, 07:21 PM | #14 |
Would any or all of these coatings also work OK on my headers as well? They definitely need a cleaning up and made to look better.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
10-12-2016, 07:35 PM | #15 | |
It would be great if the POR paint would work, but I think the steel gets too hot, and won't dissipate the heat like the cast iron manifolds. |
10-13-2016, 12:20 AM | #16 |
Thanks, yeah, I could see that. Perhaps I will just need to add better headers to the check list. Mine run down and collect down by the transmission area, so I take it those are long tube?
