advantage of aluminum water pump ?
I just pulled out my water pump ,Thinking about replacing it with an Edelbrock water pump, I like how they look , are they any better ? Thanks
I am using a weiand aluminum hi flow pump..its not as pretty as the edelbrock..but it works great...lighter in weight..higher flow
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
ya it's pretty much just the taste of the owner. the aluminum ones are a lot lighter, nicer and have higher flow but the stock water pump will do the job just fine and keep about 70 bucks in your pocket. But if that is the look you want....buy it!!
Bought a stock one , painted it , looks great and it was cheap ! Thanks
