Old 10-12-2016, 02:37 PM   #1
uber cool
Apache 59 door seals
As above need a pair of door seals for a 59 Apache. Where the best place to buy, ie best quality and fit? thanks
my rides
59 GMC Apache fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=684337
68 VW Westy camper
uber cool is offline   Reply With Quote
Old 10-12-2016, 03:16 PM   #2
OrrieG
OrrieG's Avatar
Re: Apache 59 door seals
I got mine from Classic but have not installed they yet. They come with clips to fit the factory holes. They are NOT Sofseal which a lot of guys swear by. I got mine in my big order, all seals, misc bolts, mirrors, visor arms, door parts so the shipping did not kill me. I did research of all the major aftermarket suppliers and the over all cost of the order was the cheapest for similar quality parts.
OrrieG is offline   Reply With Quote
Old 10-13-2016, 01:47 PM   #3
_Ogre
_Ogre's Avatar
i believe my door rubber came from lmc truck, as did most of my parts
remember to install it correctly, your first intuition will be to install it backwards (like i did)
this is the correct method
shop air compressor timer
Old 10-13-2016, 03:08 PM   #4
uber cool
thanks guys, Ogre, did your seals clip on or glue in place?
my rides
68 VW Westy camper
Old 10-13-2016, 04:41 PM   #5
SCHRUMGMC
SCHRUMGMC's Avatar
I've seen both, not sure the advantages to the glue on. The clip on seems to be the way to go
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 10-13-2016, 07:59 PM   #6
OrrieG
OrrieG's Avatar
even with the clips I am going to use sealant, clips just help with positioning and holding in place while the gorilla snot sets up. Don't forget the stainless bar across the bottom to keep it from sagging, and there are a few small clips at the tight corners to keep it in place.
Old 10-14-2016, 01:35 PM   #7
_Ogre
_Ogre's Avatar
i used the clips, only glued a couple small places in the curves around the latch
that normally would have had small screw in clips
glad i used the clips because i had them backwards and had to turn them around
i also glued the corners together as my repop door bottoms had square corners
i didn't have the ss trim orrieg mentions
