Diff cover with fill plug? 12 bolt
Has anyone bought something like that?
1982 K10 SWB 1987 V20 - Sold - Doh! |
Re: Diff cover with fill plug? 12 bolt
Why not just use the fill hole on the side of the differential?
I should say I did look for one a few years back, but never really found any that were less than $150.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
I'm using this one.
http://www.ebay.com/itm/ALUMINUM-196...VX7wcs&vxp=mtr You can see it installed on my build thread. ![]()
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
![]() Join Date: Sep 2013
kinda unclear but its made by LPW..
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
There is weld in and bolt in bungs with a plug you could put on a stock cover if you don't want a fancy cover. Same deal for a trans pan.
-Cody |
I may have to go this route. I started this thread because my fill plug is snapped off in the housing. I'm pondering trying to extract the remains somehow.
I installed an LPW cover today. Man it is beefy! The flange is 9/16" thick. Really cool piece.
![]() Join Date: Jun 2009
Fill me in please, how does one actually snap off the fill plug ?
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
Well it was stripped out when I got to it. I tried my best to get it out using hand tools and nothing. I had someone weld a bolt to it and it snapped off while trying to turn it. Weird turn of events but I've decided to fill and drain from this nifty new cover. I never-siezed the bolts of course.
![]() Join Date: Feb 2002
Pretty. What's the retail on that much cast aluminum?
#12 | |
But how would you add gear oil if the driverside fill plug on the differential was not usable? I see a well placed drain plug on the bottom, but no way to top fill. Just roll the truck over on its roof, fill it, and roll it back, right? [lol]
#13 | |
#14 |
I know. But that wouldn't help the OP, who had to grind off his OEM fill plug.
#15 |
I think he means the cover. Not housing. It's right under the rib halfway up
-Cody |
#16 |
That must have been a cheap plumbing plug that broke off ? I think the female 3/8 drive is sunk deeper than flush. I have rounded them out and welded a bolt to get them out, but never had one break off. I replace them with a brass plug with a male hex end, not super tight either.
-Cody |
#17 |
I have a '72 K/5 tub parts truck. It had the female 3/8'' hex plug on the diff. It surprised me since the differentials on the '67s and '68s have a square iron plug end, about 1/2'', 9/16'', or 5/8'' -- not sure since I always use a 12'' crescent wrench -- but they're bulletproof.
#18 |
Ya. The earlier square male ones have a dimple on the backside, don't they? If they would snap, I would think it would leave a hole and threads around the outside
-Cody |
#19 |
Highly unlikely they ever would, unless the temper of the metal has compromised by high heat -- like a fire.
#20 |
$150 😭
#21 |
Thanks. Not a priority just now. But it would be nice.
