Help on torque specs for entire rear suspension etc.
Hi guys,
I have been searching all day and found a ton of conflicting information and I am hoping you can help me with the following... I need torque specs for every bolt on the rear suspension... 1. Where the trailing arm meets the crossmember (pivot bushing) 2. The U bolts that hold the trailing arms to the rear end 3. The upper and lower bolts that hold the rear coil springs 4. The upper and lower bolts that hold he hocks 5. The upper track bar bolt (also does anyone have a stock measurement for this? I purchased and adjustable one and want to get it as close to factory) Thank you in advance!! |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Help on torque specs for entire rear suspension etc.
Have you looked for an assemble manual?
What year ya working on? https://www.brotherstrucks.com/mobil...tinfo/LFA6066/
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I was trying to avoid buying one but I will if I can't get the answers from you truck restoring vets!
Working on a 1964 C10. |
1. Where the trailing arm meets the crossmember (pivot bushing) - 140 ft-lbs
2. The U bolts that hold the trailing arms to the rear end - 200 ft-lbs 3. The upper and lower bolts that hold the rear coil springs - 55 ft-lbs 4. The upper and lower bolts that hold he hocks - 50 ft-lbs 5. The upper track bar bolt - I couldn't find this one this morning but I believe I took it to 75 ft-lbs on mine |
#5 | |
No problem!
Looking again, I found 85 ft-lbs for the frame side track bar bolt. |
#7 | |
Or what book are you using for these specs? |
#8 | |
Are yoy looking for everything from ball joints to control arms? |
