10-08-2003, 11:23 PM | #1 |
Trouble Starting
90% of the time my truck starts up just fine. Then every once in a while I will turn the key and it sounds like the starter motor is running but it doesn't turn the motor. Whats the deal? The starter isn't even a year old yet.
Nick Rodenberg 72 Cheyenne 10 V8 350/TH350 white/ochre/white/ochre, ochre/saddle interior Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!! |
10-09-2003, 12:00 AM | #2 |
Firefighter
Sounds like your starter bendix is getting bad. It's the little cylinder looking thing attached to the starter that your wires hook to, it engages the starter.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
10-09-2003, 01:10 AM | #3 |
Recovering Truck Driver
or you have a few broken teeth on the flexplate
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
10-09-2003, 01:59 PM | #4 |
Thanks guys, I'll check it all out this weekend.
10-09-2003, 02:09 PM | #5 |
Robert Olson Transport
ya may also wanna check your grounds and connections to the battery and starter sometimes therye dirty and it happens that way
10-09-2003, 02:49 PM | #6 |
I went through 3 reman. starters before I finally got a good 1 u didn't say if it was a reman. or not just thought I would let u know what happened 2 me.I told them to check it before I took it and put it on and they did and when I would put them on ech 1 had a different problem.But I would sure check out what the others said above before I took it out.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
10-11-2003, 01:00 AM | #7 |
This is my 2nd reman since April of 01. The one that was on the truck when work begun on it was real tight running and turned it over real slow. The second one made terrible noises and only got worse and when they tested it it blew the circuit on their machine at NAPA. This 3rd one had been OK so far. May I should just get a brand new one next time from O'Reillys or something.
10-11-2003, 09:40 PM | #8 |
1FINE69
Also follow the shim procedure. I had a similar problem and messed around with shims until the first starter quit working. I followed their procedure, ending up with two half shims on one side(bolt), gave it a whirl and it has worked flawlessly ever since. The starter should come with a shim adjustment pin that goes between the bendix gear and the fly wheel. And always have them check it electrically before you leave the store . Good luck
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD |
