10-13-2016, 02:13 PM | #1 |
Glove Box Liner Installation
I used these two Guys advice plus added a couple of my own ideas and installed my glove box liner with no rips or tears or even a crease..
I found in search the smart ideas from these two forum members and I highly recommend you do as they suggest .. This advice is from Wes owner of Classic Heartbeat The correct installation of the glove box liner is behind the sheetmetal on the top and sides. Your glove box liner has little metal clips for the screws to go through for those areas. However the bottom of the glove box liner goes on top of the sheetmetal. Actually sandwiched between the glove box hinge and the sheetmetal. You will need to cut the liner on the end relief slits made to bend the cardboard liner around the corner. Otherwise the liner will not be supported on the bottom. WES LocDoc (Leon) has good advice on what tools to use to put in or take out the liner without damaging it.. The only thing I did to add to what they suggested is I heated up the liner with a hair dryer to make the cardboard more forgiving when pushing into place And to add to the tools used I found that a margin trowel was handy along with the paint sticks to get the liner edge up and over the sheetmetal and into place ,used it as a pry bar so to speak. I also took clear moving box tape and taped the 4 clips into place on the front lip of the sheetmetal where the liner edge and door hinge fastens down and by doing so the liner slides over it easily with hanging up .. Here are a few photos of how it looks from start to finish ,, SAM_3368.jpg SAM_3371.jpg SAM_3372.jpg
When you learn a thing a day you store up smart. Last edited by GOPAPA; 10-13-2016 at 02:29 PM. |
10-13-2016, 05:59 PM | #2 |
Re: Glove Box Liner Installation
Just bought a new liner for mine! Thanks for the ideas!
1970 C-10 LWB 1998 Jeep Wrangled TJ 2009 Honda VTX 1300 2013 Buick Enclave |
10-13-2016, 08:46 PM | #3 |
if you don't have air they just slide in from the back all that extra hose gets in the way but wish I had air
10-14-2016, 07:40 AM | #4 |
Mine has air, but I am thinking of pulling the box out of mine and rebuild it with all new seals and hoses. I took the old liner out which I think was the original. I took it out from the front and damaged it too much to put back in. It would definitely be easier to put it back in from the back side!
10-14-2016, 10:33 AM | #5 | |
I also took my whole A/C ducts apart and changed out the resisters and relays and with the glove compartment liner out of the way and the .glove compartment door off it is so much easier do.. actually I cannot see doing with them two things in place .. have fun and let us know how it all works out,,
When you learn a thing a day you store up smart. |
10-14-2016, 10:40 AM | #6 |
Pfffft... those are a cake walk... trying getting one of the hard plastic Vintage Air ones in!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
