10-14-2016, 12:25 AM | #1 |
Quick Heater Core Replacement Question
I'm about to tackle a heater core replacement job on an '84 K2500 with A/C. This truck is fairly unmolested and still has all of the factory insulation around the A/C box under the hood and on the firewall. Are there any bolts or nuts that are behind the factory insulation that I need to remove to get the heater core out? I was wondering if I was going to have to cut out and remove that factory insulation, which I'm hoping I don't have to.
Thanks.
Bob Q. '83 K2500 6.2L |
10-14-2016, 09:25 AM | #2 |
Re: Quick Heater Core Replacement Question
I believe there are 4 nuts under the hood. The one below the blower motor is tough to get to. Every thing else comes out from under dash. No insulation should be in the way. It's not a fun job but doable. Good luck.
10-14-2016, 10:27 AM | #3 |
Oh, ok. Sounds good. I was hoping I wouldn't have to disturb that insulation on the firewall and A/C unit.
Thanks!
10-14-2016, 07:49 PM | #4 |
I used a flexible socket extension and flexible extension mirror to see that bottom bolt/nut under the a/c box. Both tools are available at Harbor Freight for cheap if you don't already have them.
10-14-2016, 11:43 PM | #5 |
10-15-2016, 12:02 PM | #6 |
I would just pull the inner fender, it doesn't take long to do if the truck is fairly rust free.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
10-15-2016, 03:12 PM | #7 |
+1 on dropping the inner fender. And taking the two bolts out of the right lower dash, at the kick panel. You will see them when the glove box is removed. With those bolts removed it will give you a small bit of flex in the lower metal dash to help remove the HVAC case.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
