Old 10-14-2016, 03:59 PM   #1
72tutone
Vent Window help
Guys-
I'm jumping in head first and trying to replace the rubber on my vent windows with pop rivets. Ive read a few posts and it looks like it can be done
My question is since most knock off the two rivets adjacent to the tubular pivot rivet; do I need to take the two rivets off at the top of the window to change the rubber?
Ive circled the areas in question. At the top of the vent window there are two rivets.
I only removed the two near the pivot rivet.
Any ideas?
72tutone is offline   Reply With Quote
Old 10-14-2016, 04:08 PM   #2
35boulder
35boulder's Avatar
Re: Vent Window help
Just watched a you tube video on this yesterday. Very helpful. And I believe you will have to remove all the rivets. Look up the video.
35boulder is offline   Reply With Quote
Old 10-14-2016, 04:52 PM   #3
72tutone
Is it the one where the gent is replacing all the rivets with the original tubular style rivets?
Im replacing mine with pop rivets. Didnt know if it was a different or not.
Old 10-14-2016, 05:29 PM   #4
35boulder
35boulder's Avatar
Yes thats the one I watched and there are others. There is also a member on this forum I believe Roger Koop who is rebuilding these as well. Good luck.
Old 10-14-2016, 05:42 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Don't know if you have seen this thread or not....
http://67-72chevytrucks.com/vboard/s...d.php?t=660294
Be sure and read it all the way through.
LockDoc
Leon
Old 10-14-2016, 11:10 PM   #6
Robznob11
Robznob11's Avatar
Talking Re: Vent Window help
You do not need to remove the lower ones you have circled. But you do need to remove the top ones.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-15-2016, 11:28 AM   #7
72tutone
Even to remove the glass I dont need to remove those? So really its the only two rivets need to be removed.
Old 10-15-2016, 11:28 AM   #8
MLB57
Something that makes it a lot easier is to weld your it tool to a air chisel punch. Makes it a one man operation and s very quick I did both of mine in 15 mins and the rivets are nice and tight
MLB57 is offline   Reply With Quote
Old 10-15-2016, 11:31 AM   #9
72tutone
Did you put in pop rivets? Is the two rivets the only ones I need to remove at the top
Old 10-15-2016, 11:50 AM   #10
MLB57
No I used original rivets
Old 10-15-2016, 04:57 PM   #11
72tutone
Thanks everyone.
Old 10-15-2016, 08:10 PM   #12
72tutone
Well it looks like if you don't take off the hinge pivot rivet you have to remove the outer two rivets on the frame to pull it up enough to get the gasket on
Old 10-19-2016, 07:42 PM   #13
72tutone
Gents,
Need some help. Can you please look at the orientation of my rubber gasket and seal to make sure this is right?
The pics would be if you were looking at the driver side from the outside.
Is that gap in the gasket supposed to be on the inside or outside?
Also the seal on the division bar. Does that need to be flipped around? The higher side is facing left vs the right side. So higher side would be toward the inside.
