Old 10-14-2016, 08:28 PM   #1
WORNBRAKES
I am pretty sure....
It is an 85 but I am not certain. It was in the back of a 75 I rescued from the scrapyard.
Is this an 85 or could it be another year?
Mario
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 10-14-2016, 08:30 PM   #2
WORNBRAKES
Re: I am pretty sure....
Pic
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 10-14-2016, 08:31 PM   #3
WORNBRAKES
Front
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 10-14-2016, 08:34 PM   #4
100%Chevy
The simulated rubber trim design looks like an 82 to me.
So do the stripes.
Mike.
100%Chevy is offline   Reply With Quote
Old 10-14-2016, 08:37 PM   #5
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Something on there has a date code in it. Show me the holes where the washer bottle mounts and I can narrow it down if it's all original sheetmetal. Otherwise, it could be 83-87.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 10-14-2016, 08:57 PM   #6
WORNBRAKES
I think the washer bottle is still there. I am taking apart tomorrow and I will snap a shot of the washer bottle.
Mario
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 10-14-2016, 09:02 PM   #7
ElGracho
ElGracho's Avatar
If it has the pump in the bottle, 85-87. If not, 83-84.
Joe
Old 10-14-2016, 09:39 PM   #8
gmachinz
The hood if original would indicate a K5/Burban front end right?
gmachinz is offline   Reply With Quote
Old 10-15-2016, 01:22 PM   #9
WORNBRAKES
Washer bottle.
I may have found a factory date code.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 10-15-2016, 03:40 PM   #10
ElGracho
ElGracho's Avatar
Originally Posted by WORNBRAKES View Post
Washer bottle.
1. Not the washer bottle. That is the coolant recovery bottle. Good news is that changed too in 1985. Moved from the inside of the core support under the battery tray to the inner fender. Yours is the 85-87 version.
2. The 84 might mean late 84 (the 85 model year started in August/September of 1984) but it might just be a sequence number that is coincidental to the year.
3. As for the K5/Suburban comment... I don't understand that one. The "Silverado 10" rules out a K5. If the hood ornament makes someone think it is a suburban, they were available (and pretty common) on pickups too.
Joe
Old 10-16-2016, 10:42 AM   #11
WORNBRAKES
Thanks for the info. I have mostly been a 67-72 guy and have only owned one other square body. That was a wound earful 76 K10 swb. One of the trucks that I wish I had kept.
This one that I have now is a rescue. The PO threatened to crush it so I went and paid him what they would have. This front end was sitting in the bed as if someone was going to install it at some point.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 10-17-2016, 11:41 AM   #12
83GMCK2500
If you can get the hood popped, check the top of the support for the emissions sticker. Bottom line on it will say "this vehicle conforms to emissions standards for the 19__ model year"
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 10-17-2016, 02:45 PM   #13
Keith Seymore
Keith Seymore's Avatar
Washer bottle.
I suspect that "84" might be the build sequence number (short for "123484", or whatever).
You might find it also written on the underside of the hood, inside the fenders, on the bottom of the grille and/or on the front of the radiator support.
My truck was number "87".
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-17-2016, 06:26 PM   #14
WORNBRAKES
Any ideas on how to accomplish this task? No cable and the latch is not catching.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 10-17-2016, 06:29 PM   #15
WORNBRAKES
Not catching and is not the hold up.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 10-18-2016, 10:39 AM   #16
83GMCK2500
Do you have a hood latch to look at for reference? I have popped cable-less latches, it's tricky but not impossible. I put a small wedge under the driver side corner of the hood and used a small rod with a hook bent in it to reach behind the latch and grab the lever that the cable attaches to. Something like an old stainless antenna would do the trick, it takes a good pull. (The first few pieces I tried un-bent on me.) You want just enough wedge to get in there, too much wedge will make it that much more difficult to pop.
Devin
New Daily, the '96
Old 10-18-2016, 05:47 PM   #17
WORNBRAKES
Thanks fellas, i got it open. I tried the hook but could not get it released. I ended using two wood wedges about 5 inches from center on each side and removed the bolts. Date for emissions says 86.
It is so much easier telling years on the older brothers not to mention they did not have all the security features. That is what this forum is about though. Discussing, debating and teaching the history of the bowtie.
Thanks again!
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 10-19-2016, 12:36 AM   #18
83GMCK2500
Yahtzee! Glad you got it figured out.
Devin
New Daily, the '96
