Old 10-14-2016, 10:27 PM   #1
Robznob11
Robznob11's Avatar
Porterbuilt forward/narrowed. VS stock control arms...
Hey guys I could not find much information on these before my install so I figured i would start a thread for others to reference. I'm only half way done with on side so here are the before pics as well as side by side comparison of the arms....
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-14-2016, 11:09 PM   #2
tinydb84
tinydb84's Avatar
Re: Porterbuilt forward/narrowed. VS stock control arms...
I'm jealous....I have Porterbuilt dreams on a junkyard budget.
David
Instagram: myfabguy
Old 10-14-2016, 11:15 PM   #3
Robznob11
Robznob11's Avatar
Me too...17 years in the making!
LED TAILS
Old 10-15-2016, 09:24 PM   #4
Robznob11
Robznob11's Avatar
It will go lower but it will require cutting my fenders more and relocating my break booster. So I'm gonna leave it be...and put a stop to limit travel. I still need to do the other front side...
The new arms definitely gave me the clearance for turning in needed.
LED TAILS
Old 10-16-2016, 07:39 PM   #5
68is4me
68is4me's Avatar
On your before picture were you also bagged? I am also going to do the pb arms when money allows.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 10-16-2016, 08:01 PM   #6
Robznob11
Robznob11's Avatar
No sir, 1" drop springs, 2 1/2 drop spindles, 6" drop rears. 3" body drop
LED TAILS
Old 10-17-2016, 11:09 AM   #7
Willie Makeit
Willie Makeit's Avatar
does anyone offer 1" narrow / 1" back control arms other than PB?
I am in the market today and would love to buy the PB arms, but my schedule doesn't allow for 4-6 weeks lead-time.
Willie Makeit is offline   Reply With Quote
Old 10-17-2016, 11:32 AM   #8
Robznob11
Robznob11's Avatar
Talking Re: Porterbuilt forward/narrowed. VS stock control arms...
Well if you contact Dave through email you will find they will get you squared up quick. They told me 4 weeks but I had them in two....let them know your a board member and they may sweeten the deal for you! porterbuiltdirect@gmail.com
LED TAILS
Old 10-17-2016, 11:33 AM   #9
Robznob11
Robznob11's Avatar
Ps they are 1" forward
LED TAILS
Old 10-17-2016, 04:03 PM   #10
bbbc10
Diggin The SquareLife
Ur gonna be looking at 4-6 weeks from anybody that u order from.....Michigan metal works could make some....but why u want 1" back??
bbbc10 is offline   Reply With Quote
Old 10-17-2016, 04:52 PM   #11
Willie Makeit
as corrected above: forward, my bad
Old 10-17-2016, 05:34 PM   #12
tinydb84
tinydb84's Avatar
Check with this guy. He does a lot of custom orders. http://www.selfmadefab.com/
David
Instagram: myfabguy
Old 10-17-2016, 06:30 PM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
Those Porterbuilt arm should be on every C10 truck with a stock crossmembers and bags.
They correct the wider track width and center the front wheels I the fender opening.
Thanks for sharing!
Keith
Convert to disc brakes.
Old 10-17-2016, 08:12 PM   #14
class01
class01's Avatar
hey Robznob11, im at that point in my build. How are you running that airline? Inside the frame rail?
class01 is offline   Reply With Quote
Old 10-17-2016, 09:01 PM   #15
Robznob11
Robznob11's Avatar
I plan on running mine on the outside of frame away from exhaust. I will come through the frame just before rear bags
LED TAILS
Old 11-22-2016, 09:08 PM   #16
Ghernandez66
Ghernandez66's Avatar
This is a good thread I just ordered my control arms from PB yesterday I'm getting the forward and narrowed arms to clear my inner tubs . Hope they work ...
My 1st build 1966 C10 Swb ..http://67-72chevytrucks.com/vboard/s...d.php?t=668147
Ghernandez66 is offline   Reply With Quote
Old 11-22-2016, 09:32 PM   #17
Robznob11
Robznob11's Avatar
They will. The clearance from spindle to x member is tight. And the lack of steering stops will take getting used to but other than that I can turn near lock to lock with 255/60 15 tires and 8wide wheel . 3.5 bs. Definitely helps with fender clearance when turning.
LED TAILS
Old 11-22-2016, 09:36 PM   #18
Ghernandez66
Thanks . Did you run into issues with the tie rods and the sleeve to adjust the steering? I reed some other thread and I'm trying to figure out those issues before I ran into them..
Old 11-22-2016, 11:09 PM   #19
Robznob11
Robznob11's Avatar
Well i have a 68 drag link and cpp custom adjusters to run 71 disc set up. It uses 68 innerspring inboard and 71 inners out board. I still Ave about 1" of adjustment on both sides left.
LED TAILS
Old 01-01-2017, 11:51 PM   #20
ramz
ramz's Avatar
I got a question for you. I got the PB arms installed (running 2in springs 3in spindle) after the installation it appears the front end raised up 1/4-1/2 inch. Any ideas? Will it settle after some time?
ramz is offline   Reply With Quote
Old 01-02-2017, 12:35 AM   #21
Robznob11
Robznob11's Avatar
Well it should not raise since they are suposed to be at the same hight on lower arm. I cant say for sure because mine has bags. I can see it maybe rasing because since the arms are forward and narrowed that the bottom mount is moved in and forward some. I hade to work petty hard to get my lower bag mounts lined up to bolt them in because of this. That may be what caused it to raise some. I have also seen the top of the spring get a little out of seat and have to settle in....other than that not sure....they move the wheels in nicely tho!
LED TAILS
Old 01-02-2017, 12:40 AM   #22
ramz
ramz's Avatar
Thanks for the reply. I'm waiting on porterbuilt to reply to my email. Will update when I hear back.
