72 LONGHORN OWNER
Posting pictures???/////
what program do I need to resize my pictures to post here.It seems that I have lost that ability.
72-SUPER CHEYENNE/20 LONGHORN 70-C/30 DUALLY |
You can use PAINT. It should be on your computer already. Just open it up, go to image (top), select stretch/skew, and adjust the orizontal and vertical numbers. I adjust them equaly so the picture doesn't distort. Hope this helps!!
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Try spinnin 4 rear tars
Do u mean to add an image straight from your computer?
If you want to do one from your computer: They have to be a size under ~600x600dpi. I just use Microsoft Paint to downsize pictures. Just open it in Paint, go to 'Image', then 'Stretch/Skew'. Then type in a # ex: 50% by 50%, to make the picture half it's size. Just remember to make the numbers the same, or your picture will look funny.
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
Jinks
72 LONGHORN OWNER
Posting Pictures..Thanks
Thanks guy's I think I got the hang of it now.........
