Kick Panels with Speaker Mounts
I need to buy new kick panels for my 1987 R-10 with AC,,, LMC carries carpeted kick panels and carpeted lower door panels ,,, what I would like and have seen online for several types of cars,,, but have not found for my truck,,, is a molded kick panel that I can mount a speaker into,,, anyone know if these are for sale from anyone,,, I know as soon as I spend my money for the carpeted kick panels,,, I will find the speaker mounted ones I want
Re: Kick Panels with Speaker Mounts
It is possible to cut a hole in the kick panel and install a round speaker/grill in that spot. The speaker magnet will be very close to the metal in the rear but it will fit. I prefer that method because it does not protrude out away from the kick panel and looks a little neater.
#4 | |
here you go
http://store.73-87chevytrucks.com/me...y_Code=7387INT Quote:
- When the Reaper makes his deal, trust in your steel - '77 C10 350/350 2/4 drop and a mild street engine |
Diggin The SquareLife
Would have to cut a whole in the metal also
Correct, there would also be a hole in the metal, but it will fit.
73-87 chevytruckparts.com. Much cheaper. Use boommat closed cell foam speaker enclosures behind them.
84 step side 87 swb |
