10-15-2016, 10:02 AM | #1 |
Road trip, and my Motor ran very differently
So my 67' 250 straight 6 Tends to Idle pretty noisy because either the Valve guides are bad or my cam is worn and the lifters arnt getting full motion.
Anyways today I took a 50 mile trip down the highway going 60 the whole way. Right when I finally rolled in and parked the truck, I lifted the hood, and I swear the 250 was idling so quiet and smooth.... how is that possible?! Ha |
10-15-2016, 10:35 AM | #2 |
Post Whore
Re: Road trip, and my Motor ran very differently
Sometimes a good drive helps burn all the carbon out. Doesn't have Valve Guides so you know. Anyhow, it'd be the lifters making the noise. A flat cam won't cause valve train rattle, but a loss of power and poorer performance. A good drive never hurts.
EDIT. Does have Valve Guides....my mind read Pushrod guides. Wonder where I was. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw Last edited by TJ's Chevy; 10-16-2016 at 01:58 AM. |
10-15-2016, 11:13 AM | #3 | |
10-15-2016, 07:44 PM | #4 |
There are risks with thinning the oil to flush out sludge. Firstly, I wouldn't drive it 20-30 min. but let it idle. Alternatives to diesel are ATF and Rislone. Rislone being the safest. Also, a risk is dislodging sludge can clog the oil pump pick up screen.
I personally have done this on a "not much to loose" engine and it helped unstick hydraulic lifters. Multiple mild treatments would be safer, no more than 1 qt. The long run you gave it probably cleaned out carbon build up as said. Google Sea Foam dribble in carb method for even better carbon cleaning.
`63 C-10 Shortwide Roller 305 LT1 cam, Eddy 500 T5 |
10-16-2016, 02:44 PM | #5 | |
10-15-2016, 08:37 PM | #6 |
Well, it does have valve guides, just not replaceable ones. If the valves were just floating around it would get interesting pretty quick, lol.
As noted, the ticking at idle is probably the hydraulic lifters clattering a little from collapsing slightly and adding lash to the valvetrain. For whatever reason they pumped up when you drove it today. Not an uncommon issue at all. Also commonly transient, as you've observed. |
10-16-2016, 01:57 AM | #7 |
Post Whore
Don't know where the hell I was that day.....thought he was taking about Pushrod guides for whatever reason. Derr.....I'm a go back in my corner now.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
10-16-2016, 02:31 PM | #8 |
You can come out when your truck is fully reassembled
10-16-2016, 02:42 PM | #9 |
10-16-2016, 02:43 PM | #10 | |
10-16-2016, 02:26 PM | #11 |
TJ we all have them Homer Simpson moments DOH!
