Old 10-15-2016, 02:41 PM   #1
loujizzel
Front air ride only
Okay I'm at work and I'm thinking about things to do to my truck. Currently my truck has a drop kit.... in the rear it's dropped on blocks bolt on C notch and it looks like the previous owner remove some leaf springs and in the front it looks like all he did was cut the springs it's a real bad ride my intentions is to get a set of CPP drop spindles up front and a set of new Springs as well in the rear I want to bring it down some more, maybe some drop hangers and shock extensions to kind of get it a little lower. I got under the truck and look at the distance I have about 6 inches of play with.....i want to do is drop it down maybe 4 more inches get it down as low as I can without sacrificing cutting into the bed....now the front is where I have the question can I want to run front bags only..... some will say why not just do the whole thing because $$$$ I figured I can lower the rear and not be too worried about it but I know if I lower the front down 6-7 inches I might have problems so if I put an air ride up front and leave the rear until I'm ready to install bags in the rear well I guess my question is has anyone done this.... just put bags up front
loujizzel is offline   Reply With Quote
Old 10-16-2016, 12:02 AM   #2
UKNOWME
UKNOWME's Avatar
Re: Front air ride only
So you're implying your rear is flipped, has blocks and you still want to go another 4 inches? That would mean you would be lowered 11-12" in the rear. I don't think that would be possible and still be able to drive it. As far as the front goes yes you can do just a front setup and add the rear later if you want.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 10-16-2016, 06:10 AM   #3
andrewmp6
And the front you can only go so low before you drag the lower a arms they are the lowest point in the front.That is why most run a dropmember or a raised crossmember because that.The rear the center of the rear end will hit the bed before anything else happens.
andrewmp6 is offline   Reply With Quote
Old 10-17-2016, 05:45 PM   #4
midnight rambler
midnight rambler's Avatar
I have 4 inches of clearance on my lowers and plow asphalt all the time. you can install bags on the front only. I was going to do just that but ran out of funds. you should look at my setup sometime. also get ahold of Jason pang at cammods hes the man when it comes to air bags
midnight rambler is offline   Reply With Quote
Old 10-17-2016, 10:37 PM   #5
loujizzel
Semd me some pics brother
Old 10-17-2016, 10:47 PM   #6
loujizzel
I seen this truck and I know it's an older version and Ours it's probably an 90s vehicle he did a 9/12 drop on his vehicle and that's why I thought I can do it on mine
Old 10-17-2016, 11:00 PM   #7
bbbc10
Diggin The SquareLife
Your jus not gonna buy parts an go that low. Your gonna have to cut the bed an out a bigger notch in then add bars in the notch so they dont flex etc...if you wana go that low might as well jus bag it
bbbc10 is offline   Reply With Quote
Old 10-18-2016, 10:46 AM   #8
midnight rambler
here's some pictures of mine. no c notch, lower spindles with cut springs. 17'' rims.
Old 10-18-2016, 11:00 AM   #9
JWall
Frequent Flyer
JWall's Avatar
For height reference... This is bagged front & rear without cutting the front or rear inner fenders, an uncut bed floor, & a bolt in c-notch.
The tires hit the front inner fenders before the control arms will hit the ground.
The rear has an adjustable bump stop to keep the rearend from hitting the bed floor when aired out.
I used an Ekstensive kit in front. http://ekstensive-metal-works.myshop...-1-ton-15-22in
So, Yes you could use this kit (or one of the many similar kits) in front and roll a static drop in back.
- Justin
1 Owner 1976 SWB
Old 10-18-2016, 09:24 PM   #10
GMC-YA68
GMC-YA68's Avatar
That stance is perfect JWALL
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 10-18-2016, 09:43 PM   #11
loujizzel
Attachment 1581909
Attachment 1581910
That is it!!!!!
Details if you ever have the time
Old 10-18-2016, 09:52 PM   #12
loujizzel
I also found this
Old 10-18-2016, 09:55 PM   #13
loujizzel
Attachment 1581909
Attachment 1581910
Jwall truck is sweeeet. Did you put the kit together or you bought a kit already complete
Old 10-18-2016, 09:59 PM   #14
loujizzel
I would like your stance and save money from having to mod my bed and inner fenders.... i will be rolling 20's
Old 10-19-2016, 07:53 AM   #15
JWall
Frequent Flyer
JWall's Avatar
Thanks guys!
The front is just an Ekstensive kit as I mentioned.
The rear is a kit I dreamed up.
It's a very simple 2 link design (sorry 2 link haters!)
It allowed me to use factory front hangers, the factory shock mounts, worked with my K5 blazer gas tank & my existing bolt in c-notch.
The adjustable pan hard bar is in front of the rear end because of the K5 tank.
All of the air management stuff is where the factory drivers side gas tank would be.
Mounted compressor & tank to the frame then made a plate that attaches to the side of the tank (using Accuairs killer tank brackets) to hold relays, valve block, junction point, etc.
- Justin
1 Owner 1976 SWB
Old 10-19-2016, 07:57 AM   #16
JWall
Frequent Flyer
JWall's Avatar
I mentioned earlier about an adjustable stop in the notch to keep the rear end from hitting the bed floor.
The notch was actually too big so we welded in a plate & then drilled & tapped a hole for a bump stop so you can thread it in/out easily or add spacers as needed to keep it from hitting the bed floor or to add rake if wanted.
- Justin
1 Owner 1976 SWB
Old 10-19-2016, 09:02 AM   #17
blazer2007
Thanks guys!
Attachment 1582239
Attachment 1582240
Attachment 1582241
Attachment 1582242
I was wanting to do a simple 2 link like yours,is there a thread or a post on how you did it.sorry for budding in.
blazer2007 is offline   Reply With Quote
Old 10-19-2016, 09:08 AM   #18
loujizzel
This is awsome..... great stuff brother
Old 10-19-2016, 09:32 AM   #19
JWall
Frequent Flyer
JWall's Avatar
http://67-72chevytrucks.com/vboard/s...569216&page=14
- Justin
1 Owner 1976 SWB
Old 10-19-2016, 02:54 PM   #20
bbbc10
The 2 link jus bolts right in
