![]() Join Date: Jan 2016
Dont have casting #on back of block. Vo327u7 is stamped on passengers side just below cylinder head on flat spot. Head has a raised l cast on head. Original engine in truck! I have been told it is a 307. What does vo327u7 indicate? Vin# ke149t83070 dd rockwell standard t221n6 trans. Thanks for any information and this site
Re: 69 k/10 vo327u7
Check that suffix code again.
No u7. Then look here to decipher it. http://www.nastyz28.com/gm-chevy-cod...s-suffix-9.php |
![]() Join Date: Apr 2012
Re: 69 k/10 vo327u7
Any chance U7 is UT?
UT 1969 307 M/t 200 4 K-10 & 20 |
Re: 69 k/10 VO 327 U7
I rechecked stamping on passenger side of engine just below head on flat spot. VO 327 U7 block# 36M 3956632 VIN KE149T83070 DD . What does VO 327 U7 indicate . Do I have a 327 ? Is there a link here I could ID this. THANKS for any help. HAPPY TRAILS
Re: 69 k/10 vo327u7
V0327 means your motor originated in Flint on march 27.
Your casting code indicates a 1969 307. Still can't find your suffix code U7. http://www.mortec.com/castnum.htm |
Re: 69 k/10 vo327u7
THANKS G99 for the information and link! Maybe the 7 stamping was a mistake!
Re: 69 k/10 vo327u7
Possibly!
Should be UI for that 307. The 'I' might look like a '7'. http://johnscabin.com/tuff/Engine-codes/small/9.htm |
Re: 69 k/10 vo327u7
How do I remove this post?
