![]() Join Date: Oct 2012
Ideas for polishing my Steering Wheel ?
I've tried using fine rubbing compound and that's helped but it takes a lot of rubbing.
Thought maybe someone knows a better way. My wheel is black and I don't want to remove it for the polishing. I would appreciate any ideals.
Larry 84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles. "It's a sorry man who can't find his wife a good job" |
Re: Ideas for polishing my Steering Wheel ?
I think I'd pull the wheel, chuck it in a vice, and machine polish it with a rag ball on a drill or something similar. Not removing the wheel is probably false economy in terms of time saved.
You could also start with a heavier grit of compound and then finish up with finer stuff.
Here you go.. (original GM steering wheel Vapor buffing patent pdf document attached).
Don't try this at home though without a big ole vapor canister breathing apparatus or preferably separate supply. Shortcut is just to buy the OEM repro |
Make that "OER" not "OEM"..
![]() ![]() Join Date: Feb 2009
As I understand it, you can sand using light grit sand paper to 2000 grit and the finish will look as good as new. I bought an extra steering wheel which is great, but for some reason it's a bit dull. I've already ordered 2000 grit and plan to test the theory on a reject first.
On a side note, I've read the same applies to belt buckles. Can I ask what compound you are using?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-21-2016 at 12:27 AM. |
#6 | |
![]() Join Date: Aug 2014
My dad always says that HEI distributers are pointless... •1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money.. •1967 c10 with tach, dropped 3/5 on deep dish rally's •1972 Cheyenne Super. Sold |
