Old 10-17-2016, 05:19 PM   #1
demian5
demian5's Avatar
Broken Pinion Gear
Well this weekend the pinion gear went in my 70. It was a 373 and has a posi.
It would be great to find a used set of 373 gears or even better a 3 series posi and a set of 308 gears to go with the turbo 350 and 30" tires.
Anyone have experience with this swap and the change it made towards drive-ability on the freeway vs off the line?
Anyone have a gear set / posi laying around they want to part with?
Thanks in advance for your help.
I saw a great write-up on the site on how to do the replacement and setup. I've never done one, but it gave me the confidence to do it myself.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 10-17-2016, 08:00 PM   #2
cleszkie
cleszkie's Avatar
Re: Broken Pinion Gear
What axle do you have? That will help people determine if they have what you need. If you have a 14bolt full-floating rear with 10.5" ring gear, I have what you need. But you probably have something closer to stock.
cleszkie is offline   Reply With Quote
Old 10-18-2016, 11:24 AM   #3
demian5
demian5's Avatar
Oops, I thought I added that. I have a 12 bolt. I found a guy that has a beautiful 3.08 open rear end with ring and pinion and he wants little for it. It is out of a 1980.
He switched ratio because he went with a ls and 4l80 and 3.08 was silver state run speeds in OD.
Will this 1980 12-bolt diff unit fit in my 1970 12-bolt diff unit? Of course I will buy all the bearings and shims for my 1970 model unit.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 10-18-2016, 08:43 PM   #4
Mike C
Mike C's Avatar
It will fit. Bearings and other parts should be the same from the two.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-19-2016, 10:37 AM   #5
demian5
demian5's Avatar
I appreciate the response.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 10-19-2016, 11:08 AM   #6
mcbassin
Still Learning
mcbassin's Avatar
I'm sure someone on here has what you need for your truck. You can pay a small fee, HERE and post a wtb ad in the parts section.
If I had a set, I'd send them to you. The only extra set I have is 2:72, not a good fit for you.
What transmission do you have?
mcbassin is offline   Reply With Quote
