Old 10-17-2016, 10:34 PM   #1
Esoza
88 chevy 1500 want to swap it to 66 chevy body
I have an 88 chevy 1500 and I want to swap the body to a 66 chevy which I also have, I just do not know where to start. First project.
Esoza is offline   Reply With Quote
Old 10-19-2016, 07:49 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: 88 chevy 1500 want to swap it to 66 chevy body
Start with a. Tape measure, sawzall, and a welder.
Not a great first project. You would be better off swaping parts from the 88 to the 66 if it already has a frame.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-19-2016, 08:04 PM   #3
Esoza
Old 10-19-2016, 08:05 PM   #4
Esoza
You are right, unfortunately the 66 was crashed and the subframe is toast
Old 11-01-2016, 05:41 PM   #5
Esoza
Update on my last post, i took the advice that was posted to transfer the parts from the 88 chevy to the 66 subframe everything is going well, the one question that i have is will the spindles from the 88 chevy fit on the 66 A arms
Old 11-01-2016, 06:14 PM   #6
padresag
if the 88 is a suburban or crewcab then you can swap things over. otherwise the cutoff is 87. it is more advisable to switch the complete frt crossmember.
if you look thru the FAQ section above there is quite a bit there. also tells which components which may work with others.
sometimes what you have because you have it is not the easiest answer nor the cheapest
ron
padresag is offline   Reply With Quote
Old 11-01-2016, 06:58 PM   #7
Esoza
ron
Old 11-01-2016, 06:59 PM   #8
Esoza
Originally Posted by Esoza View Post
Thanks for the info.
