10-18-2016, 02:41 PM | #1 |
First start advice.
Okay so in 2 weeks we should be trying to crank over the motor (im heading outa town for a week tomorrow) and am wondering how we should go about it, just crank it until it starts, or what?
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2005 Silverado 2500hd(tow pig) Made in the USA, just like my trucks |
10-18-2016, 03:03 PM | #2 |
Re: First start advice.
I would need some context. Has it been sitting 2 weeks? 2 decades? What's the scenario?
10-18-2016, 03:34 PM | #3 |
according to the p.o its been sitting since nov. 2015. and when it last ran it was for a quick drive around the yard.
10-18-2016, 03:46 PM | #4 |
Go Pack Go!
I'd pre-oil it. Pull the distributor, find a junkyard distributor shaft and hook it to your power drill. It gets the oil pump working and prevents dry start that could cause damage.
10-18-2016, 03:57 PM | #5 |
Thanks and also foun a lil history on my truck. (its a funny story)
10-18-2016, 08:07 PM | #6 | |
You could also (in addition, not instead of) pull the plugs and shoot oil into each cylinder and then turn if over by hand a couple of times.
10-18-2016, 08:18 PM | #7 |
All about them K’s
I use marvel mystery oil in the cylinders of the engines I build at work. Oil will work as well. It can't hurt to squirt a little bit in each one to help free everything up and build compression. I'd prime the system too. Might be a good idea to go thru the carb if it's been sitting that long with fuel in it.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
10-18-2016, 08:22 PM | #8 |
THE most important thing to do is get oil into the valve train. Cam lobes love oil and hate being without it!
A flat blade screw driver (or old junked distributor shaft) fitted into a drill, down the distributor hole will spin the oil pump that will fill the oil galleys nicely!
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
