10-18-2016, 08:16 PM | #1 |
Posting for Keith Seymore
Hi Keith, Thanks for responding to my PM. Here are the PICS for the question I asked. Thanks Again, John
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. |
10-19-2016, 09:18 AM | #2 |
Re: Posting for Keith Seymore
what is that called? Fender seal? Where can they be purchased?
10-19-2016, 12:38 PM | #3 |
I have never found those aftermarket , had to find good used. I believe it would be called a fender cab seal. Nice truck.
10-19-2016, 02:47 PM | #4 |
We used to call them "elephant ears".
It does just curl under at the bottom; I think it used a bit of adhesive to hold it until the fender is installed, although there is a hole in the seal which looks like it might receive a Christmas tree type push pin. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-19-2016, 02:57 PM | #5 |
So what do these accomplish? Less wind noise?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
10-19-2016, 04:01 PM | #6 |
Thanks Keith, I'll stick um till the fender goes on.
```````````````````````````````````` ```````````````````````````````````` Matt Man: I was told that it keeps the wind and the dust from getting inside your cab. We'll see if that is true. ````````````````````````````````````````````` ````````````````````````````````````````````` BamaDave: I heard that the cab to fender was it, but fender to cab sounds better. They were hard to find but are out their, I got mine from a place called "Collis Truck Parts " in PA. Thanks Everyone, John
10-19-2016, 04:38 PM | #7 |
When I removed mine, they had never been removed. They just had some type of self-tapper in them.
