Old 10-18-2016, 10:00 PM   #1
wander1969
12 bolt rear end pan hard bar?
Im looking at a 12 bolt posi rear end. It was from a leaf spring truck so it does not have the mount for a pan hard bar. The truck will be bagged but not laying frame. Is there some kind of bracket they make to run the pan hard bar? I have also seen a cage that bolts on the rear diff cover with two bars on it to keep the rear end centered better. Any info would help. Thanks in advance.
Also my truck is a 69 c10 with coils(bags). I do understand that i will have to weld saddles for the trailing arms.
Tyler
wander1969 is offline   Reply With Quote
Old 10-18-2016, 11:13 PM   #2
1972CheyenneSuper
1972CheyenneSuper's Avatar
Re: 12 bolt rear end pan hard bar?
Early Classic makes a Super Track Bar that moves the axle mount to a bracket on the passenger side trailing arm. I actually just installed mine about an hour ago as I also put a leaf spring rear into my truck. They sell the saddles as well.
http://www.earlyclassic.com/catalog.aspx
1972CheyenneSuper is offline   Reply With Quote
Old 10-19-2016, 07:37 PM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
You probably want a longer bar that mounts to the trailing arm.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
