Old 10-19-2016, 10:11 AM   #1
72kool
72kool's Avatar
door panel questions
My '72 door panels are in good shape except the plastic is (flakey?) if your finger touches them when cranking the window, you will get plastic under your nails. Is there any way to sand them down and repaint them to look nice? they are otherwise in good shape and i dont want to spend 200 on parts i dont really need for a DD. Also where is the best place to buy new plastic tree clips ? The door panels are parchment so where would be a good place to find a paint to match?
1972 GMC C20 Custom Camper 350/TH350
72kool is offline   Reply With Quote
Old 10-19-2016, 10:31 AM   #2
ForrestHead
Re: door panel questions
I wonder if you could spray a poly on them or some kind of sealant. My 72 had rotten plastic panels when I got it, I came across some metal 71 panels dirt cheap and switched them over with pretty much no problem.
ForrestHead is offline   Reply With Quote
Old 10-19-2016, 12:02 PM   #3
boogieman1
boogieman1's Avatar
I had pretty much the same issues with my 72. I found automotive interior paint that said it would work with hard plastic and then matched the color the best I could. I went through 4 different colors before I found the one I liked the best. I painted a small section of the back before I did the front. For prep I hit then with a scotch bright pad then cleaned with blowgun then denatured alcohol. Sprayed 3 coats then a clear coat of the same brand. After a year they are holding up well so far. I bought the paint at Pepboys.
'72 chevy C20 Cheyenne Super
boogieman1 is offline   Reply With Quote
Old 10-19-2016, 12:15 PM   #4
72kool
72kool's Avatar
after cleaning them and going over them with a scotch bright pad, did the paint keep it from flaking anymore? also is there a self filling paint to use that would help or do you have to use an interior paint?
any pictures of the ones that you guys did? i would like to see both the painted ones and the earlier model ones please
Old 10-19-2016, 01:15 PM   #5
ForrestHead
Mine have since been upholstered, but that's the 71 panel underneath.
Old 10-19-2016, 01:39 PM   #6
rsgt
rsgt's Avatar
My 72 door panels are doing the same thing. They have peels so much that the grain is gone so I do not think painting mine would look good. Here is what I plan on doing to mine. I am going to sand them to get the loose flake off then I am going to try some rustoleum brand spray can bed liner and try to put a light texture on it. Then paint them with some rustoleum satin black paint.
rsgt is offline   Reply With Quote
Old 10-19-2016, 01:39 PM   #7
72kool
72kool's Avatar
what did you have to do to make it work with the 72 oor and the longer studs on the window crank and door handle?
Old 10-19-2016, 02:29 PM   #8
ForrestHead
Honestly I don't remember having to do anything, but it was a while ago. My 72 wasn't a Cheyenne so the panels were about as flat as the 71 panels. I used some escutcheon plates that I came across at the pick and pull.
Old 10-19-2016, 02:53 PM   #9
plastercracker
cut your finger nails lol
plastercracker is offline   Reply With Quote
Old 10-19-2016, 04:00 PM   #10
72kool
72kool's Avatar
im a mechanic so they never need cut haha. i never have em.
do you have a picture of what escutcheon plates you used, forresthead? i guess i dont know what you are talking about
Old 10-19-2016, 04:03 PM   #11
72kool
72kool's Avatar
never mind. i understand what your saying. guess ive never known the actual name of them.
Old 10-19-2016, 04:06 PM   #12
ForrestHead
The spacer rings that go behind the handle, on the outside of the panel. I just found some old chrome ones from an old Oldsmobile or something and used them cause I liked their look. Now that it's upholstered, it has prob a 1/4" backing mayerial and then a velvet type material over that, and they fit perfect without a huge escutcheon. So there would only be probably a 1/4" gap at most with the 71 flat panel on there. Does that make sense? I'm kinda bad at explaining things, ha.
Old 10-20-2016, 07:15 PM   #13
rsgt
rsgt's Avatar
I painted mine today with the rustoleum truck bed liner. There are more pictures on my build thread.
Old 10-21-2016, 10:14 AM   #14
72kool
72kool's Avatar
those door panels look really good rsgt.
i like the idea but wonder if i could still paint it parchment after....
Old 10-21-2016, 10:25 AM   #15
67ChevyRedneck
67ChevyRedneck's Avatar
Whatever you do, don't even consider buying the repops.
http://67-72chevytrucks.com/vboard/s...d.php?t=713190
RSGT, is this what you used? I can't believe how flat it laid out? They look really nice.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-21-2016, 10:55 AM   #16
rsgt
rsgt's Avatar
I think you could. It drys pretty hard.
Old 10-21-2016, 10:55 AM   #17
rsgt
rsgt's Avatar
Yes, that is it.
