Old 10-19-2016, 11:08 AM   #1
WarMonger
WarMonger's Avatar
Booster and Proportioning valve
Where is the best place to get anew booster and proportioning valve? This is for my 70 C20 3/4 ton
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 10-19-2016, 08:32 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Booster and Proportioning valve
You can get an unloaded booster from NAPA. That's where I got mine.
Alco, https://www.google.com/search?q=70+c...utf-8&oe=utf-8
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-19-2016, 09:46 PM   #3
davepl
davepl's Avatar
For my 1970 3/4 2500 I bought one from www.brakeboosters.com
I forget where I got the prop valve, but I know they're not cheap (like $250 from memory).
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-19-2016, 11:45 PM   #4
FirstOwner69
FirstOwner69's Avatar
70s had 4 wheel drum brakes. Has yours been converted to front discs, or is it still original? The hardware you are asking about is different disc vs. drum.
FirstOwner69 is offline   Reply With Quote
Old 10-20-2016, 12:33 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^^ What he said. There was no proportioning valve with your drum/drum system, it came with a distribution block. Similar appearance but different inside.....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 10-20-2016, 03:21 PM   #6
WarMonger
WarMonger's Avatar
Correct, mine is drum drum, so I need the distribution block. Do you know where to get that at?
1970 C20
-_--_--_- ______
1972 K5
Old 10-20-2016, 04:52 PM   #7
FirstOwner69
Inline Tube...
http://www.inlinetube.com/_p/prd14/2...on-block-pr112
I thought they also sold the bracket, but I don't see it on their website. Might be worth a call though. Those they have for the cars don't look right.
Old 10-20-2016, 05:09 PM   #8
davepl
davepl's Avatar
I should point out, as other's have noticed, that mine is a '72 front disc conversion, it also had drums and no prop valve originally. Sorry, I completely forgot it wasn't original to my truck!
Old 10-20-2016, 05:21 PM   #9
Grumpy old man
Grumpy old man's Avatar
Save your money use piratejack.net call them and describe what you need or what problem your having and they'll take care of you ! Great prices and great custom service .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 10-20-2016, 06:02 PM   #10
davepl
davepl's Avatar
What are you suggesting, that he rebuild his own booster? Just opening one requires an arbor press and courage.... and it's not the safest thing in the world either, there's a ton of potential energy in there. Enough that it can fly all the way across your shop and hit your Camaro.
Old 10-20-2016, 06:20 PM   #11
WarMonger
WarMonger's Avatar
another brake question. Is there a difference in the lines ( like dia) between a 1/2 ton and 3/4 ton? Or do they all use the same size lines?
1970 C20
-_--_--_- ______
1972 K5
Old 10-20-2016, 06:53 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Did you check the link? www.piratejack.com
That's not what he is suggesting at all...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-20-2016, 07:18 PM   #13
Grumpy old man
I don't own any Camaros , I had a few and moved up to classic Corvettes , Who said anything about rebuilding anything ?
