Old 10-19-2016, 12:24 PM   #1
arts62
Drop Shock suggestions for 1962 C10
New to the forums. Did a ton of digging, hoping someone here can help.
1962 C10, Long bed, T-bars turned up, 2" blocks in the rear.
I need some shocks.
Thanks!!
arts62 is offline   Reply With Quote
Old 10-19-2016, 01:03 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Drop Shock suggestions for 1962 C10
What's your budget for the shocks?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-19-2016, 06:07 PM   #3
LVPhotos
LVPhotos's Avatar
I ran Pro Comp before and after bags. Toxic shocks rear now still a pro comp with different sticker. KYB up front. Amazingly KYB is available at O'Riely in stock. You need to measure for proper hieght. Make sure unload weight is middle of full open/close 3" minimum.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
