Old 10-19-2016, 05:18 PM   #1
OUbesto
OUbesto's Avatar
Hard shift from second to third gear
Guys,
I have a '70 c10, 402, th400, LWB. TH400 tranny shifts extremely smooth from 1st to 2nd and 3rd to 4th. However when it shifts from 2nd to 3rd, it slams into gear. At low rpm it isn't as noticeable but given a little throttle, as soon as it shifts into 3rd, there's a hard jolt! Again, upshifting in other gears is smooth as well as downshifting is good. Any ideas?
1970 C-10 CST, LWB, 402/400, A/C
OUbesto is offline   Reply With Quote
Old 10-19-2016, 08:27 PM   #2
firedemon
Re: Hard shift from second to third gear
th400 only has 3 speed
firedemon is offline   Reply With Quote
Old 10-19-2016, 09:09 PM   #3
OUbesto
OUbesto's Avatar
Duh! You're right, somehow when I was typing details I thought I had too many shifts...ha!
The hard shift occurs when shifting from 1st to 2nd gear. 2nd to 3rd shift is very smooth.
Old 10-19-2016, 09:35 PM   #4
trac209
Make sure your vacuum modulator is connected or adjusted
trac209 is offline   Reply With Quote
Old 10-20-2016, 01:58 AM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
http://chevroletforum.com/forum/silv...nd-gear-52050/
I think this would apply to a 400 as well, not sure.
"Drop the pan back down, remove the 1-2 accumulator housing and pull the piston. Check for a torn piston seal or broken spring, but moreso for a wobbled out piston hole, which is probably the culprit."
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 10-20-2016, 11:19 AM   #6
OUbesto
OUbesto's Avatar
Thanks guys for your input. I'll give both suggestions a try and report back!
