10-19-2016, 07:21 PM | #1 |
user # 2756
Step side bed wear strips
So i disassembled the 1986 8' stepside bed i purchased last weekend to get it ready for some new wood and hardware. I was expecting the same type of construction as the bed on my 70. Boy was I wrong, the angles welded to the bed sides have studs vice carriage bolts. I figured ok, I can work with that. Then while removing the "square nuts" holding the bed wear strips in between each board I find they are studs too. Again not carriage bolts. I mention this because my 70 bed has all carriage bolts holding the wood in place.
The issue, some of the studs broke off while I was attempting to remove the nuts. From what I can tell, all the "bed bolt kits" include carriage bolts and not studs i can press in. What have you all done? I don't want to buy new strips since the ones I have are solid. Here are some pics, sorry for the poor light.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
10-19-2016, 11:22 PM | #2 |
Re: Step side bed wear strips
I have put the strips upside down on some blocks of wood and put a socket on the back over the head of the stud and tap it out backwards. They usually pop right out but a little bit of heat will help pop them out without bending the strip. Then I had the round holes on the original strips punched out square at a welding shop for 50$ or so I think. The side strips I drilled the spot welds to the sides and drilled the heads off the bolts and had them punched out square as well
-Cody |
10-20-2016, 06:38 AM | #3 |
user # 2756
Dreading that, but I am going to see if I can find a square punch. Thanks Cody.
10-20-2016, 08:48 AM | #4 |
Maybe some button head bolts without the square shoulder would work. But at least with the square holes it would be easier to work with next time
-Cody |
