Old 10-19-2016, 10:26 PM   #1
74baggedbug
Tie rod question
Trying to figure out what these are off of.. my truck has disk brakes and I know the calipers are off a 78 but when I went to buy replacement towrods the 78 would not mount to the spindle.. I tried 68 tie rods but the threads were to small.. this truck is a Frankenstein
74baggedbug is offline   Reply With Quote
Old 10-20-2016, 04:00 AM   #2
Overdriven
Re: Tie rod question
67-70 drum brakes had their own tie rod, 71-72 discs got a different tie rod. I don't know if it's possible but you may have 73-87 calipers on 71-72 spindles.
Overdriven is offline   Reply With Quote
Old 10-20-2016, 05:22 AM   #3
Metaldoc
Metaldoc's Avatar
Some disc brake conversion use the one ton outer tie rods. bigger diameter main right handed threads on outer rod and smaller left handed inner tie rods.
Metaldoc is offline   Reply With Quote
Old 10-20-2016, 05:28 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I would try the 71-72 version.
Same thread as the 73-87 tie Rod, with a different spindle taper.
Keith
Convert to disc brakes.
